Question about Dell OptiPlex GX200 PC Desktop
Dead comp when i boot up my optiplex gx200 a blue screen comes up that says its checking the disk drive. when it finishes windows starts and then it goes to the blue screen o death. i can get to the system restore but it will not boot in any safe mode, and last known good configuration isnt working
  • 112 Answers
Sounds like your hard dive has gone.
Posted on Mar 27, 2008
    Genius:
  • 3,587 Answers
I'd say you are suffering from a hard drive breakdown, perhaps...can you boot from a CD?
Posted on Feb 28, 2008
I need to run CHKDSK/F on my Dell optiplex GX200, which IS NOT this computer, and I have no idea how to go about do so. Any advice?
Another way to run Chkdsk is to use an operating sytem disk if you have one. Sometimes the blue screen will occur when you try to get into Safe Mode so you'll Insert the Operating System Disk in the cd drive, reboot from the operating system disk and select the option to Repair. It will search for your operating system and once found you will select it by entering a 1 for windows. Then it will ask for the Administrator's password which in most cases is blank so just press enter. When you see the Dos Prompt simply enter the command: chkdsk /r
Check disk will run well over an hour and you will notice the percentage of completion going from high to low, but that's normal. Let it run to completion then reboot the machine.
If you still have issues, then you'll need to reinstall windows. Try doing a Repair Install which preserves your music, pictures, documents, data and videos.
Windows XP Repair Install:
Insert the Operating System Disc in the cd drive and boot from it.
When the Options come up select the Option to Install Windows (Don't select Repair). It will start loading windows files and at some point it will ask you to accept the License Agreement by hitting F8. On the next screen after hitting F8 it will begin searching your system for an already installed operating system. It should find yours and give you more options to which you want to select the option to Repair. This will preserve everything you have on the system.
Mar 22, 2012 | Computers & Internet
What sequence do I go through to reset software with a boot disk on a Dell Optiplex
hello ggpgh1
If you are using the actual windows disk, have it in the CD/DVD drive
1-turn the computer on
2- press F12 as it starts
3- from the boot option that comes up choose internal Cd Rom drive
4- if the hard disk has or has had windows on it you get a message "press any key to boot from CD"
5- press any key, the computer starts to boot from the disk. from then on follow the prompts.
good luck
please leave comment if this has helped.
Feb 08, 2011 | Dell OptiPlex GX260 PC Desktop
I have a compaq v 2000 and when i turn on the comp safe start menu comes on then when i type enter for start windows normally a blue screen shows up and the computer cuts out or turns off automatically...
Unplug all additional devices, printers, external drives, network cards, etc. If it won't boot into safe mode, you will need a windows disk. Load the windows disk, and if it's Vista or 7, get the advanced repair options, and do a system restore. If it's XP, just do the computer repair. Windows vista also has a startup repair you can run from the Windows disk. We need to know the operating system to help you
Jun 13, 2010 | Computers & Internet
My comp in not stating, showing blue dead screen,
Use your restore disk, or if you have a Windows OS disk, bootup with that.
When you see the screen that gives you an option to "Repair Windows" hit the "R" key. You will be taken to a DOS prompt. Choose the Volume you want to repair (Usually number 1) then it will prompt you for an Administrator password. If you have never put one on the system, simply hit Enter. The it will take you to "C:\Windows" Type in the following...
"CHKDSK /R" (without the quote marks and hit Enter. Let chkdsk utility see if it can repair the volume. It will prompt you when it is finished.
Apr 25, 2010 | HP Pavilion m7490n PC Desktop
DELL Optiplex GX110 freezing
Check the settings of the internal setups. This is using the BIOS itself and hitting a particular key before anything happens. On some machines it is F1 or the DEL key. In the basic setup there are settings for the boot order and floppy drives and HD type. Make sure these are set correctely.
ALSO on one of mine I have to use a formatting/partitioning program supplied by the HD manufacturer (in this case Maxtor) to pre-prepare the drive beofre trying to install WIndows.
Sep 08, 2009 | Western Digital Elements powered by WD 320...
How do I reset my Dell Optiplex 360 to factory settings?
back up all of your data(music,documents,videos)before you do this..if you can't boot up then use ubuntu,slax or other types of bootable cds. also be sure to download the drivers from dell.com put them on a flash drive just in case automatic updates don't get it to set it back to the factory setting you are going to have to get a xp installation(asuming it is xp,or what ever disk came with your comp)the disk should say operating system on it.what you do is put the disk in and boot off of it.if this message don't come up 'press any button to boot from cd......' then your going to have to go into the bios and change the cd drive before the harddrive.if the message does come up hit any button and wait for the blues screen.after it is loaded hit enter f8.if a screen says existing operating systems hit esc(on that screen there is a option to repair the os but you have to know th command lines to do so).if not and it goes to the partion screen then delete the existing partion and create a new one.to do so go to the partion and (delete)hit d L enter.(create)c enter. after you have formed a new partion hit enter....it will format the drive(delete everything)after it is done formatting it will start to instal the os.in xp it will stop 2 times for your input.after everything is done loading you should be able to custamize everything and install things.in the bottom right hand cornor there should be a marker telling you to activate windows.click it and use the product key on the side of your comp(laptop under it)if there is none there try keyfinder.i will email it to you if you can't find .also be aware that you have to reinstall office, antivirus and other programs. so make sure you have all of the cd's.
Aug 05, 2009 | Dell OptiPlex 740 Desktop Computer
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
My dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Feb 17, 2009 | Dell OptiPlex GX200 PC Desktop
Dell OptiPlex GX200 PC Desktop Logo
128 people viewed this question
Alun Cox
