Cannot connect to internet, DSL get message network cable not connected works fine on another computer
Sound like you could have an issue with the network card. Try running your network trouble-shooter unless your computer savy. If so, then you know what needs doing.
Posted on Feb 28, 2008
My router shows connected but no internet access.
Please try connecting the DSL / Cable modem directly to your computer and check if the network works fine, it works fine then power down the wire router and then restart it again and check.
Jan 02, 2011 | Linksys WRT160N Wireless Router
I'm trying to connect dsl directly to my laptop - but when I connect the eithernet cable from the dsl modem to my laptop it says there is no internet connection??? The dsl cable works fine with my...
Maybe the laptop is configured by default to look for a wireless signal through its wifi drivers, or a different previously installed modem. Go to your Computer/Control Panel/Network Sharing Center and set up a new connection there so your computer knows what to do.
Nov 02, 2010 | Dell (0E828) for Latitude C610 Modem
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computer says connected to internet,, wont display page
usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Feb 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
Sonicwall Internet Connection Issue! HELP PLEASE!!!
juz clear the arp entries or else change the connectivity cable from modem to firewall.
Aug 21, 2008 | SonicWALL PRO 230 Firewall
Suddenly lost internet connection on 2Wire DSL modem
hmmm...only thing that makes sense here is that your dSL is unhappy...did you check that phone line into the modem? that's what the internet light means when it's out, actually..if its not the line, then it's the modem..
not much else that is off on this.
check your computer warranty here 4 FREE
Feb 28, 2008 | Computers & Internet
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Dec 29, 2007 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
