Problem hooking tv to stereo
I have a zenith z50p3 plasma tv that i am trying to hook to my stereo. i have the audio cable(red/white) connected to the aux on the stereo and audio cable (red/white) connected to audio on tv but nothing happpens. what am i doing wrong
Lwsmith91 you need to make sure that there is only one audio output on your stereo. if more than one try plugging it in to both outputs. also make sure that you do not hear any sound when you plug it in or its the wrong one. on the back of your tv make sure you dont have them plugged in to an HD input or output for that matter
Posted on Feb 28, 2008
On my Zenith z50p3 plasma tv, I have picture , but the sound is scratchy, I have to raise the volume to 40 before I hear something,and then it is very irratic. Some say it's the sound amplifier. D
First check all your wiring with it turned on wiggle the connections and you mite find you have a dodgey plug somewhere or a break in the wiring
Dec 14, 2017 | Zenith Z50P3 50 in. Plasma TV
After warm-up screen flashes and loses color but comes back on and off intermittidly. This is a 50" Zenith Plasma tv. thanks.
Sounds as if a cable connection is bad. Check the cables first. If cable are good, change inputs, if cables are bad replace cables. If it's component, make sure that red, blue or green didn't come loose on both sides...the tv and the source. If you still have problems, check for red video noise on the screen itself, preferably when it's on but with on input (black) If you notice this, your plasma is failing.
Mar 23, 2011 | Zenith Z50P3 50 in. Plasma TV
I have a zenith tv older model, and have dish network, i need to know how to hook it up and switch it over so i can play it
If you have an HD receiver you will want to use one of two types of cables; you can use component cables which have five ends red, blue, green, red and white, or you can use an HDMI cable which will have one flat connection. If you have a standard definition receiver you will want to use RCA cables these have three ends red yellow white. The connections will be labeled on the television as well as the receiver. Once you get this connected hit the input/source button on your TV set if you're using RCA cables you want the TV set to video 1 or video 2. If you're using an HDMI cable then set the TV to HDMI 1or 2 using the input /source button. If you use Component cables set the TV to Y/PB/PR or component 1/2.
Daniel Busa
DISH Network Customer Service
Mar 09, 2011 | Zenith Z50P3 50 in. Plasma TV
I am trying to hook my wii to my Onkyo receiver. The Plasma is a Pioneer and you can't hook the Wii directly to it. I have the yellow, white, red cable that comes with the Wii.
Hello Julie
Thank you for using Fixya!!
OK, this is actually very easy once you get the hang of it:
The Yellow, Red and white cable you have, is actually the Video(Yellow) and the 2 stereo Audio cables(Red and White).
Now, the Yellow wire goes into the video port on the gaming unit, and into the Video input port on the TV itself. This is usually The AV channel's port.
The white and Red cable goes into the audio port on the gaming console, and into the audio in or AUX port on the receiver.
This should do the trick, but you will need to remember the following:
Once you want to use the gaming device, you should set the TV on the AV channel, n=and the receiver on the AUX channel.
Feel free to let me know if yu need any further assistance.
Kind regards
Lock123
Feb 20, 2011 | Onkyo TX-SR608 Receiver
How do you get the audio to go to the stereo stystem? Do I actually need the digital optical cable???
Just connect the RED AND WHITE RCA jacks to the audio line out of the TV and feed another ends of the cables to your stereo AUX or TV audio in.
Dec 09, 2009 | LG 60PS11 Plasma TV
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
Sound through stereo
that is very easy, just get an RCA cable, the one with red/white and if your tv has audio output connect the RCA cable to it and the other end to AUX into your stereo, change your input selector on the stereo to AUX every time you want to litsen through stereo speakers.
good luck
Jun 18, 2009 | iLO 3200 32 in. LCD Television
I cant get any tv audio on my samsung ht-z310.
Red and White cable wires are usually for Audio wires. Make sure yo connect it to either Audio (Red & White) Out or Aux Out in your TV and connect it to your Audio (Red & White) In or Aux In in your Sound System/ Home theater.
Mar 09, 2009 | Samsung Audio Players & Recorders
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
