Question about Elo Computers & Internet
We have Elo model ET1987c-4 sw-1 open frame monitors We have found that we have to much HT voltage going to the line output transformer, the voltage regulator (IRFS634B) goes short also the Line output transistor (C5387) goes short circuit, also resistor R571 goes open circuit. Can anyone help a schematic of this model would be a Godsend as we have about 5 of this monitors and all seem to have same problem.
  • admin586 Feb 29, 2008
    would be prepared to pay for correct circuit diagram for the ELO ET1987C-4
  • Anonymous Mar 27, 2014
    need pdf for manual
I have the schematic on this board if you would like to send me a email ill send it to you..
Posted on Dec 10, 2008
Lg crt 29 inch tv wont start
The frame amplifier, like the line amplifier, will not work if there is no output from the oscillators for them to amplify.
Early 405 line sets didn't have a frame oscillator as they used the sine wave from the AC mains but I believe the later sets needed a frame oscillator and a sync signal from the rf demodulator to prevent instability.
Transistors rarely fail by themselves and it is often external factors that cause them to overheat and fail and an essential part of the repair process is discovering what factors caused the initial problem. Modern circuits use a lot of multi-transistor dc coupled stages and it is often the bias of an earlier stage that is the culprit.
The frame output transformer is usually very robust and much less likely to fail than a line output transformer. I suggest you ensure the correct operation of the oscillators before going any further.
Aug 30, 2016 | LG Televison & Video
Samtron 56v power
solution 1 please replace the horizontal output transistor in near to line output
solution 2 in case you changed the horizontal output when the problem not solved follow this.
monitor line output transformer burned replace them its kept on monitor from mother board to connect thru picture tube. very carefully to change the part because its have a storings voltage capacity in heavy.
solution 3 check the signal cable
May 01, 2013 | SAMTRON 55V 15" CRT Monitor
Onkyo HT-R500 no display
Look on line for service manual. Display problem is usually traced to 1, or more, of 3 resistors in the AC supply to the display. It appears that the resistors are supposed to be 1/2 watt but the one I removed from my unit was only 1/4 watt. The resistors are mounted on a small board mounted on the front side of the main transformer - right most board. I had to unscrew the transformer to access the resistor. I looked at voltages coming out of the transformer and the the same voltages leaving the circuit board. There is a 1 Ohm, a .47 Ohm and another that supply AC voltage to different parts of the display. I found one resistor open. Replaced it and I now have an operating unit.
Feb 14, 2012 | Onkyo HTR500 Receiver
I got a ELO 1524L LCD touch monitor. The back
You should have 2 wires for 12~15 power going in, which you already indentified, 2 more wires should be for ground return, you can check for them by using Ohm meter between the chassis and probe the wire for less then one Ohm resistance. The other two wires, 1 wire will be for Dimming control (usually 0 = dimmed, 5vdc = full brightness), 1 wire will be for BACKLIGHT ON/OFF (0v= OFF, 4~5VDC = ON) control.
Dose the fuse on the inverter board check out OK? You can use other inveter board as long as the lamp connectors are the same and you just have to match the input signal pin. I have done many.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
See example of the fuse on the inverter board.
Jul 11, 2010 | Elo 15" Touch Monitor
The standby light flashes and the tv will not come on
check the power supply, its not giving out the required voltage output. if you cant repair a tv plse take it to a workshop, ask a technician to make sure that he checks the following components.
power diodes and transistor, fusable resistors around the power supply, and zener diodes.
he should make sure that an ht of 95-110 volts appears on the line transformer. later a transformer will produce various voltages to trigger other voltages to open up your tv. thanks
Mar 26, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Turn on TV, no picture but sound is ok, thin white line running across screen
You have a frame collapse problem. Line, EHT, power supply, video and sound stages are all functioning. Check frame output ic for dry joints, resolder all pins. HT supply for output ic's derived from line stage check for open circuit safety resistors around line output transformer, if you find any then frame output ic will also be suspect. WARNING Very high voltages exist around the line stage. Make cold tests with Ohm meter with set unpluged from mains supply.
Feb 27, 2010 | Toshiba CN36X81 TV
Monitor LED blinking--no display--How to open the cabinet
check the vga cable if it is attached properly to your computer. Make sure that the VGA cable is connected to the Video Card that you are using.
check in the manual if you need to install the driver first.
also check if the monitor will work to another computer. If not, Then you can check the VGA Cable and replace a new one.
Hope this will help you out .. =)
Aug 24, 2009 | LG Studioworks 700S 17" CRT Monitor
When I switch on monitors the power comes after long time. Sometimes it takes 30 minutes
Get your Monitor Checked. Most probably the High Voltage transformer causes this problem. The output high voltage which activates the tube, is not getting sufficient voltage. Change the HT Transformer by a technitian.....................sodeep
Apr 30, 2009 | Computers & Internet
Screen goes black,with sound
No picture sound ok
Note 1 a Raster is the name for a screen made of lines of brightness
Note 2, A Blank raster has no snow or picture, its just a lit up screen
Sound ok but no raster.
First increase tube's first anode voltage (knob on the loptx) to see if the screen is just too dark.
if after you have turned up the bottom knob on the loptx, there is still no brightness,check, for crt heaters, and EHT 25kv and focus voltage (2kv) and A1's/Screen/G2 voltage is 300-600v.
and check for field timebase (height), the next thing to check is the sandcastle pulse.
If it's present, colour decoder chip is probably faulty or lacks supply from the LT regulators.
NO LINE DRIVE If it's absent,check the line driver, locate the loptr(big and usually has heat sink).
follow the print from the base back to the driver stage , where you will usually find a tiny transformer with 4/5 pins
resolder it, even if it looks good,then with power on, check for voltage on all its pins, 2 should have LT(12v to 32v) or HT (90v to 150v), if not there follow the print back and look for either a transistor(linedrivetr), or the feed voltage line (maybe regulated),
If the voltage is ok on two of the driver transformer(drvtx) legs, the look from the base of the driver transistor to locate the timebase chip
and check round its pins for a 12v supply line, if there ,replace the timebase generator chip
Method of testing line drive, remove line output transistor, and connect a normal red led, across the B/E (longest leg to base), and when you power up the led should lite up.
Trace the pcb back from the BASE leg to find the line driver stage,
Its usually a very small transformer (4/5 legs) and a transistor connected to it,
The driver transformer legs(pins) will be two with voltage and two without
The two with power will either be about HT level (110v=145v) or about LT level(25v)
If not then trace back and look for a biggish 3w resistor.
If the voltages are correct the look for line pulses from the Timebase oscillator chip to the base (some overvolts protection circuits remove pulses if ht is too high).
If the voltage is low and the feed resistor is getting hot then check the base of the driver transistor if its HI over 0.5V then its being turned on by the timebase oscillator chip (protection ?)
If the voltage is zero check the feed resistor
If all seems normal check that 12v is getting to the timebase oscillator chip (IC) (12v regulator?)
Hope it may help you;
Regards,
VOTIT
Oct 10, 2008 | Philips 42FD9954 42 in. Plasma HDTV
ViewSonic P815 VCDTS21492
1.Remove all spark gapecapacitors at RGB cathodes and G2, G1 cathodes.
2. Remove G2 pf (G2 cathode to Ground).
3.check video section any dry points.
4. Replace boosting FET (power supply output to LOT supply)
Oct 01, 2008 | ViewSonic Computers & Internet
Computers & Internet Logo
366 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
shahid_ptv
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
