Question about Initial DTV-322 32 in. TV/DVD Combo
Picture On S-video the screen has two black areas on the sides of the picture like widescreen but just the opposite!???Need a Full Screen
  • Opii Feb 29, 2008
    Thanks!
  • 593 Answers
Shot in 4:3 and your TV is 16:9
Posted on Feb 28, 2008
I have a black frame around the tv picture.
Go into Settings and play with 'Aspect Ratio'. Remember though, not all shows are made in Widescreen format, and certainly nothing made older than 10 years ago.
Mar 30, 2017 | Televison & Video
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
Dec 01, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
When viewing a dvd on our Bravia we can't set the picture to the full screen. We get black areas above and below the picture.
This is called widescreen, nothing is wrong with the tv or dvd, Look on your box of the dvd it will say Widescreen. This is the exact picture as it is in the movie I got this question all the time when I sold Tv's at sears for 3 years. Again nothing is wrong.
Nov 27, 2009 | Sony BRAVIA KDL52XBR2 Television
It shows picture not in full screen like the movies black screen at top,in middle is the picture,black screen at bottom
If this happen on DVD's it is because the DVD is formated to Widescreen, 16x9 size, your TV is 4x3 size. Unless the Menu has an option of Picture size, or Format, to set to Full screen. there is nothing you can do other than be sure to check the DVD for picture format size before purchasing.
Sep 28, 2009 | Hitachi 43F300 43" Rear Projection...
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 22, 2008 | Samsung BD-P1400 Blu-Ray Player
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
ILo-26HD Tv
take your set to a tech you are having problem in your vertical output circuit.leaky filter or coupling capacitor,or defective B+ regulator transistor or IC .buffer transistor or IC,or supply resistor, they need to be replace.good luck
Mar 26, 2007 | iLO 2600 Television
Initial DTV-322 32 in. TV/DVD Combo Logo
67 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
