Question about Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
H550 blue tooth
I did not read all the instructions before I tried to pair my phone w/the headset. I entered the wrong passcode, now I can't make it work for me. Any suggestions
  • Anonymous Mar 28, 2008
    I PURCHASED A BLUETOOH MOTOROLA H555. WHEN I WENT TO FIND THE DEVISE ON MY PHONE ITS ASKING FOR A PASSCODE IM NOT SURE WHERE TO FIND THIS. I HAVE READ EVERYTHING AND I STILL CAN'T FIND A PASSCODE
  • GLM1 Apr 17, 2008
    Lost instruction booth. Don't remember how to pair my H550 with my phone.
Go into your phone's bluetooth settings and delete the connection for the headset.
Posted on Feb 28, 2008
How to pair Motorolla 550
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Oct 29, 2010 | Motorola Mobility H550 - Bluetooth Headset...
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Aug 05, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Pairing bluetooth
Erase bluetooth's memory first. Hold both volume buttons along with call button for 10 seconds. Then shut it off and back on. When you turn back on it will take a couple seconds and will stay lit blue. At that time, you need to go into your phone's bluetooth status and add a new device. The passcode is 0000. Good luck!
Jul 10, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Bluetooth
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Bluetooth® Headset H555
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Jan 14, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
PASS CODE
thanks sooo much this worked wonders!
Nov 01, 2007 | Plantronics Explorer 330 Headset
Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset Logo
74 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
