Question about ASUS A8N-SLI Premium Motherboard
Asus A8n-sli premium with amd 64 3700+ proc
I have the motherboard hooked up and when I turn the power on it loads up great threw the bios info right up until its about to load windows I get a blue screen and the computer resets itself have all kinds of theries but cannot figure out why it keeps reseting the hard drive is good was taken out of my other computer fully installed so its not the hard drive help me
  • Anonymous Dec 03, 2008
    I have the exact same problem same mobo and everything. Used my old hard drive which always worked fine but with this mobo it goes thru the bios but resets itself right before loading windows.
  • 32 Answers
Usally blue screen errors are from ram. Do you have the right ram for that board?. Is the ram set to the right speed in bios?.
Posted on Feb 28, 2008
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Does this motherboard have sata plugs on it
Short answer: Yes. More info from Tom's Hardware:
http://www.tomshardware.com/s/reviews/a8n-sli/
You can also go to ASUS's website www.asus.com to download drivers, BIOS updates and manuals for more still.
I hope this helps!
Jun 07, 2010 | ASUS A8N-SLI Motherboard
A8N Sli motherboards graphic card and CPU capatibilies
Hi!
Nop, it takes only AMD
The infosite about that MB is still up, you will find it here:
http://uk.asus.com/search.aspx?searchitem=1&searchkey=A8N-SLI
There you will find all the info you want. BTW, its not only the MB's size if the nvidia card fits or not, its the size of the case to.
Good luck
Nic
Apr 07, 2009 | ASUS A8N-SLI Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Usb 2.0 problem
If you do turn off USB 2.0, you may have two options, "Full Speed" and "HiSpeed". Make sure you use "Full Speed", as it's faster than "HiSpeed". But the real answer is that you need to install the USB driver for your motherboard. If it came with a CD, insert the CD and read the instructions on installing drivers from it; otherwise, check Asus's website under the Support/Downloads section.
Oct 01, 2007 | ASUS A8N-SLI Premium Motherboard
ASUS A8N-SLI Premium Motherboard Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
