Question about Intel DG965RY Motherboard
Onboard Audio Problem
My motherboard is Intel DG965RY. The problem is whenever i connect my speakers to the rear socket of the motherboard I can only hear the right channel. No sound comes out from the left channel. I've tried adjusting the balance knob but nothing happens. Please help.
    President:
  • 317 Answers
Make sure you have the jack plugged all the way in.
Also, try a different set of headphones/speakers.
Posted on Feb 28, 2008
Speaker not detected
Hi, try this link for your drivers: http://www.userdrivers.com/Motherboard/Intel-D915GAG-Motherboard/
The link at the bottom of the page is what you need.
Hope this helps
Jul 24, 2010 | Intel D915GAG Socket 775 Motherboard -...
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
Intel D865GBF motherboard's onboard sound card is not giving signals to speakers . Sometimes only left speaker works but mostly none of them works. I tried many media players & many speakers. But while...
it is the problem with the back side motherboard sound port.
so u can purchase another sound card and install it. it cost about 6$ (Rs 300.00 )
If it helps RATE ME PLS
Jun 25, 2009 | Intel D865GBF Motherboard
Speakers doesnt play
check the motherboard manual and see if it requires a jumper to enable the audio onboard ( if so get the jumper from your motherboard box and seat it on the correct jumpers in the correct position to enable onboard audio ( assuming its onboard audio that you are using ) If not then ensure your sound card is seated firmly and install the correct drivers ( for either the onboard audio or the dedicated sound card ) and then ensure that the speaker cables are connected to the correct connectors on the sound card ( whether onboard or not ) and make sure windows audio is not muted for any of the auxilary lines ie wave etc and if its realtek ensure that you have 2 speakers selected in the HD Control panel and not head phones.
May 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
DG965RY mother board mic recording problem
this MB supports 5.1 audio out. try the laest drivers & bios updates & see
http://www.intel.com/support/motherboards/desktop/dg965ry/index.htm
Nov 18, 2008 | Intel DG965RY Motherboard
Intel DG965RY Motherboard sound problem
which operating system are you using? follow this link http://downloadcenter.intel.com type in your motherboard number DG965RY and then select support from overhead menu
Oct 31, 2008 | Intel DG965RY Motherboard
My audio is not clear
Open volume control, click on advanced settings and turn down bass
Apr 16, 2008 | Intel DG965RY Motherboard
Audio Jack Problem
check any other driver installed before the current driver......
Aug 15, 2007 | Intel D946GZIS Motherboard
Intel DG965RY Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
