Help Display shows F-05 and flashes. Water in machine. Tried to put through cycle and also tried 'pump out'. No go. What is wrong? is there any way I can get door open so I can at least get clothes out. Water in kitchen sink is draining ok. Thanks
  • alice18 Feb 28, 2008
    Sorry Coldcut - you are wrong. The only panel at the bottom is a plastic one about 4 " deep which when removed reveals a solid metal plate. There is no filter for the user to empty and nothing in the instruction book about this. Any more thoughts?
    Alice 18
    Genius:
  • 1,554 Answers
If this is a front load then there is a filter in the bottom access panel of the machine. open the panel 3 screws on bottom, open the large filter and clean it out of debris.
Posted on Feb 28, 2008
  • Karl Whisenand
    Karl Whisenand Feb 28, 2008
    Well could post the model number
    it sounds like a portable clothes washer.
    I assume the washer fill works ok.
    does it spin at all.
    to open the door on some models you hold the signal button 10 seconds.
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Stops mid cycle and the 400 and 0 spin lights flash
According to the service manual ( which you can download ) it is the fault code 05 which means NTC failure. This is the water temperature sensor.
Feb 17, 2013 | Whirlpool AWM6120 Front Load Washer
I have a Bosch she4ap06uc/05 quick wash light flashes. I have tried to reset it and it will not reset. The sump pump work and drains all the water out of the machine. It turns off and on fine but when...
Bosch she4ap06uc/05 This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 13, 2011 | Dishwashers
F-05 flashing on the display screen
Hi There
I have this for to read and hope this helps out. Let me know how this works out.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Washing Machines
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HOTPOINT WT940P
Lower the outlet hose into a low bowl, if water flows then you need a new pump cost around 20 pound to buy, If no water comes out the you have a blockage somewhere.
Nov 29, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Oct 25, 2007 | Washing Machines
Help anyone. Machine will only start for the first minute
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. Check the Water Temperature Sensor, Heating Element and Element Relay Check connections to the Sensor, Heating Element and Relay Hope this is helpful.
Sep 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
