Question about Maytag Neptune MAH6500A Front Load Washer
5 year old model, walking across floor, violent movement during rinse cycle causing LR code not going into spin. In Service Mode ran the quick check for codes and everything fine got the PA code. This morning my wife put load in and same problem. Any ideas?
  • 41 Answers
Sounds like some sort of broken support or spirng underneath. Flip it over and look. Expect a little water to run out though.
Posted on Feb 29, 2008
MY WASHER MOVES VIOLENTLY AND THEN GIVES A LR CODE
I would check the balance of machine by using a leveler and checking the bottom leg adjustment on all 4 legs then check the
suspension springs, counter weights, dampning straps etc.
Jun 10, 2015 | Maytag Neptune MAH6500A Front Load Washer
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Maytag Neptune MAH6500A Front Load Washer Logo
247 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
