Question about Gaggia Baby Espresso Machine
New gaggia baby class "d" espresso mch
Brand new out of the box the mch does not want to pump water (the pump makes a noise but only a dribble comes out - then all 4 lights start to flash - the manual states this indicates a problem - any ideas
  • 2,039 Answers
It seem the pump is not prying itself you have to inject water try with a turkey blaster the pump to put juice on a turkey fill it up with water start the machine inject the water in the water hole try that out let hope it work if not you have warranty good lock
thanks for using fixya
pierre
Posted on Feb 29, 2008
Have a baby gaggia coffee machine and unable to find anywhere that will service or repair. The machine has worked really well for 3 years but now is making aloud noise when working and the flow is very...
The loud noise is coming from the vibrating water pump.
One posibility is that is full of scale or and dirt so you can try descale the machine.
Second is probably the water tank can fit corectly on the base and the valve on it does not open correctly or not at all so the pump it can not s**k water but air or a mix of them so we have the loud noise.
Finally you can remove the shower disk on the group head , locate above where you place the filter holder and clean it probably is full of dry coffee and block the water way out.
Please note that can be all above problem together.
Good luck
Mar 27, 2010 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
The pump isn't pumping. The machine is making the
Hi
There are no diaphrams in high pressure pumps. They use a small piston and check valves that can become stuck. Some can be fixed but that old it might be better to get a new pump. You can sometimes find them on ebay.
Oct 14, 2009 | Gaggia Baby Espresso Machine
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Aug 12, 2009 | Gaggia Baby Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
No water getting through to the coffee holder
If the machine is making very load noise while trying to make coffee ie. water to grinds or steamer this is more than likely a pump problem.
Dec 26, 2008 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
354 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
