Question about Linksys Wireless-G Broadband Router
Internt getting knocked off
I have 3 computers at home and i have linkys router and one wireless so when i go online and my wife goes online on her computer all of sudden the internet on my computer goes down but shows that it is connected tell what should i do
    Problem Solver:
  • 6 Answers
What model is your router?
Posted on Feb 28, 2008
I misplaced my linkys cd. Is there any other way I can install linkys onto my computer to make in wireless?
The best thing to do is install Tomato or DD-WRT firmware on your router. This will increase your router's potential ten-fold.
Lifehacker did an excellent write up on doing this. Go to: http://lifehacker.com/#!178132/hack-attack-turn-your-60-router-into-a-600-router
Hope that helps!!!
Feb 14, 2011 | Linksys Wireless-G WRT54G Router
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
1.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
2.
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
3.
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
4.
turn on modem, linksys then pc
5.
loging to windows - open IE on address bar type 192.168.1.1 - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
6.
Now try yahoo.com in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
I have linkys wireless router model wrt54g2v1.after i back up my computer i lost the linkys file. i cannot find cd for installation. now i am unable to open internet.
mpshyla
The reason for the CD is to configure the router to your cable modem. So if you reinstalled your computer you do not need the CD again. All you need to do is set the computer's Gateway back to your router. The links below will help you do this.
http://www.fixya.com/support/r4602477-check_change_computer_ip_address_in
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Aug 09, 2010 | Linksys WRT54G2 Wireless Router
Computer will connect to internet when connected
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
May 21, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I need security code # for my wireless linkys router
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 06, 2010 | D-Link Computers & Internet
My laptops cannot connect to linkys router
You can wire directly to the modem, then go to d-link website.
Feb 02, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wrt54gs
Ok first thing to do here is to reset the router and reconfigure it back, To reset it just press an dhold teh reset button of therouter to 15 seconds while the power is ON then after that power OFF the router for 5 seconds, If you have teh setup CD of the router just run it to the main computer and let it reconfigure the router back for you, but if you don't have the setup Cd of the router you can manually configure it by accessing the router setup page if you're not familiar on how to that I will dvise you to contact Linksys tech support and let one of their tech walk you through with that process and also they updating the firmware of that router that will also help alot in solving your problem, this is the number for linkys 800-3267114....
Hope that helps.........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
Connecting DLink thru Comcast Cable Modem and Vonage box
first you see the in the internt explorer in that tools in that is give internet option in that connection>lan settings> if the proxey server is ther then remove it if not ther then go it. i think you get it.
second think is that in your dlink router reconfigure the router properly and give the isp details correct and one more thing is check the dns value.
Jun 12, 2008 | D-Link DIR-625 (790069292637) Wireless...
How to get a third computer to work on my wireless network
is the adapter connected to the router? are you using wep? is the firewall disabled?
Nov 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G Broadband Router Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
