Question about GE Spectra JGBP30 Gas Kitchen Range
GE Spectra Oven won't heat
I have a GE Spectra oven model JGBP35BEA7BB. The problem is the oven won't heat. I set the temperature and hit start, but nothing happens (no sounds, no flame from the oven, digital reads 100). The broiler works still works, though. This is the 2nd time in 4 years this has happened. The first time we had a technician repair it for a couple hundred dollars. I am looking to avoid this costly repair and fix it myself if possible, but need assistance. Thanks!
  • alliet Mar 13, 2008
    A new bake ignitor worked! We were able to order a new bake ignitor on ebay for $40.
    President:
  • GE Master
  • 2,651 Answers
I would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Posted on Mar 08, 2008
Why t takes long time for oven to heat up?
Does the oven actually heat up with the temperature more than 100 or does it just stay at 100? Alternatively, when you open the oven can you see the orange glow of the flame through the vents in the bottom of the oven and hear the gas hissing?
Aug 18, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas oven spectra xl44 takes forever to preheat &sometimes will not
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Will all that said, more than likely the ignitor is bad in the oven, not drawing enough amperage to allow the safety valve to open. Even though the ignitor is lighting up and glowing, I'm 99% certain that this is the problem. Here is the part number for ignitor. WB2X9154 and can be ordered from any parts distributor or from a local supplier.
Jun 21, 2012 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Oven taking very long time to hit temperature. set at 400 it takes forever (1/2 hour) then gets stuck at 398
    Replace the oven ignitor. (they get weak after a period of time, and will give those results, or stop heating altogether)
    Nov 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    F2 flashing on screen of my GE Spectra oven.
    Your oven temperature sensor has failed and must be replaced.
    May 20, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
    GE Spectra XL 44 wont keep temperature
    Replace the oven temperature sensor part # wb20k0004
    Mar 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Temperature control
    sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
    Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven does not maintain temperature. Part 2
    sometimes when they get hot that is when they fail
    Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Spectra XL Oven does not maintain oven temperature
    I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
    Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Open Questions:
    See all GE Spectra JGBP30 Gas Kitchen Range Questions
    GE Spectra JGBP30 Gas Kitchen Range Logo
    600 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
