Little nub (acts like mouse) in keyboard that controls the pointer
The little nub is malfunctioning and sending my pointer to the top or bottom of the screen. Even when I start using my Logitech wireless USB mouse to circumvent using the keyboard nub I still have the problem. Can I disable the nub on the keyboard or do I need to replace the entire keyboard? Be aware that I'm not technically inclined when it comes to doing hardware transplant surgery so would prefer a disable option.
There has to be a way to disable the nub either via software or inside the laptop somewhere, there just has to be *sigh*.There has to be a way to disable the nub either via software or inside the laptop somewhere, there just has to be *sigh*.
You can't post conmments that contain an email address.
If you hover the mouse pointer over the little speaker in the bottom right corner and right click you can turn it on from there. Or open the control panel and look in the Audio section you can turn the sound on from there. With out seeing your keyboard I can only suggest you look for a key with a little speaker with a line through it. you may also need to press the "Fn" key or the "Alt" key at the same time.
After you remove main cover face mouse right side up, wheel towards you. On end away from you there are two little nubs that stick up. Between them is a little indent where you just use a fingernail to pull up on battery holder-do not force as it should pop up very easily.
You could try changer your mouses speed settings.
To do this go to Start>Control Panel> And open Mouse. Then go to the Pointer Options tab and turn up the speed under "Select a pointer speed"
This might be a little different depending on your OS.
If you turn it up and your mouse is still slow try cleaning the lens on the bottom.
If it still does not work, try to return it and get a different one.
1-Firstly you go to system control panel(Start button->setting->Control panel)
2-select the mouse option and click
3-you see the 5 option under it,select the pointer options
4-under the visibility option unmark Display pointer trails &
Hide pointer whilt typing option
and also check the pointer speed option under pointer option.
5-than ok..
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
go into your control panel and look in the mouse or keyboard Icon, Open it and look at your pointer properties. Set all to Default and see if that gets the mouse back and working right, If that still don't work try an external mouse for a desktop and see if it still acts erratic, If the other mouse don't work right there may be a problem with the hardware that operates the mouse actions. Let me Know if that gets you going in the right direction, Ok Thanks
