Question about GE WSXH208A Front Load Washer
Moldy smell in front load kenmore washer
Three year old front load washer has moldy smell. It was fine for two yearsbut now I must keep the door open and run bleach through every two or three weeks. We have checked and cleaned all hoses and the tub and gasket help!!!! We have a 2 year old GE front loader. About 3 months ago we started smelling a musty, moldy smell. We have to leave the door open to air it out. So relieved to know we aren't the only ones.
  • jomalley Apr 01, 2008
    I have a Kenmore front load washer with this same problem except the smell began shortly after I got it. I keep the door open, run bleach through it, cut down on how much soap I use, nothing has helped. I also noticed my whites come out with weird stains on them. Recently I realized the tub is not draining completely as I can hear water sloshing around when I wiggle the machine. This must be the source of the problem? What do I do about it?
  • wtfk Sep 05, 2008
    We have an L.G. front load washer that a year after purchase left clothes and towels smelling moldy. Whats worse is after drying off the smell is transfered to you.have tried everything suggested with no results. Would not recommend to my worst enemy. Furthermore L.G. was not helpful at all.Soon as i can save up some money i will be going back to top loaders.
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Posted on Sep 14, 2008
  • 4 Answers
Bleach, baking soda or vinegar may take care of it. If none of these work there is a cleaner sold at www.smellywasher.com
that I haven't found a negative post on. I haven't used it but saw it on KTRK Houston abc news the other night. It's $16.00 but they say it's a year's supply. It also claims to remove towel mildew smell. Good luck.
Posted on Feb 29, 2008
    Genius:
  • 3,587 Answers
You may find that running a baking soda solution is more effective for this. comes from water that's been treated up stream of your home,
Posted on Feb 28, 2008
Me too with front loader i threw mine out and bought a top loader love it. except you cannot get smell out of clothes tried everything good luck to you the laundry industry needs to come up with a solution this is ridiculous. my children should not have to wear smelly laundry!!!!!!!!
Posted on Sep 11, 2008
Kenmore elite HE4 moldy smell
keep door open after you use it....keep them open until you use it again.... door can be opened just a little, but can not be closed
let machine work once with highest temperature without anything inside..... with little detergent you always use.....to wash away that smell...
if you keep it closed, then moisture will remain in and provide good environment to bacteria causing black mold to live there.....
you can remove that only mechanically..... take some old dry dampcloth and wipe it away.... it will take some time and hard work.:)
Jan 13, 2014 | Kenmore Elite 45986 Front Load Washer
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Run an empty load with bleach and detergent and/or ammonia on hot.
Dec 21, 2008 | Washing Machines
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
739 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
