Question about Acer Aspire 3000 Notebook
Acer Laptop does will not switch on.
Will not power up. Power supply is working but light does not show on computer when plugged in. Battery has been holding charge for approx 10 minutes.
    Sergeant:
  • 324 Answers
Good morning!
Have you actually checked the output of the powerpack with a meter? Then, check your power input jack, where you plug in the power pack to the laptop. It may have come loose and need to be resoldered, or replaced.
Ron-
Posted on Feb 28, 2008
Battery of my Acer Aspire 4810T does not work. With the power supply plugged in, the indication of the battery is "85% available (plugged in, not charging). If the power cable is disconnected, the...
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
1.
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
CARLO
Apr 13, 2011 | IBM ThinkPad T40 2373 Notebook
My acer aspire 6530 suddenly stopped charging the battery, it works with battery, works with battery and main power supply (yet, as long as the battery is still charged), and it certainly doesn't work with...
Seems like this is the case of a bad power supply adapter, and needs to be replaced. But to make sure we are on the right track, you mention towards the last statement, you said that when your laptop is off, and the battery is installed on, and without the power supply, the computer power button would flash and no sign of life right? Well take these step to see if it is the power supply, 1, check to see if the small green light is lighting from the powersupply adapter. If it is not, then 100% you have a bad power supply. 2, does the laptop power on when using the power adapter only, and with the battery pulled out? If not, then 85% still is your power supply and the other 15% is your power jack, either is loose, or bent, as we tend to plug in and out alot. 3, Does the laptop power on with the battery itself without the power supply adapter? If it does, it is not your battery. The reason to the laptop power light blinking with the battery installed only could be that the battery is low/drain and does not have issufiect charge to power up your laptop. And to say that when your system is on and your plug in the powersupply, and the small battery icon says it's charging but actually it is not. It could still be your powersupply, it is damaged but a smart chip installed on your powersupply only sending signal to your laptop, this chip is only to prevent the battery from over charging. So if you have another power supply, you cna test this out. But at this point, they was you described things, I believe it to be the power supply. I hope this help, if you have any question, let me know.
Jan 17, 2011 | Acer Aspire 6530-5143 Notebook PC
My acer aspire 1642ywlmi do not power at all, when i plug in the charger the charging light will show and the standby light will blink but it does'nt switch on. And when i remove the battery and plug in...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Acer Aspire 5003WLMi Notebook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
How do I charge the battery on a new Acer Aspire One Series?Netbook
Just plug the computer into the wall with the supplied power cord (while the battery is in the computer). This will charge your battery.
Sep 22, 2009 | Acer Aspire One A150-1006 Notebook
Battery Problem
Does the computer work when plugged into the power supply? If not the power supply may be the problem. If it does then I would suspect the battery has gone bad.
Dec 30, 2008 | Acer Computers & Internet
Acer Aspire 3000 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
