Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
I have a problem with my dishwasher
When we put on the dishwasher it works normally for 10 minutes and then eco and fast wash lights flash and water does'nt pump out. We have cleaned the filter and tried to re-set the dishwasher but it still will not work. Please help.Many thanks.Natalie
  • Anonymous Mar 08, 2008
    I have exactly the same problem
  • shirleydb Mar 24, 2008
    after just 15 months my dishwasher has played up tonight. the eco and fast lights are flashing and there is water in the bottom of the dishwasher. I emptied it and cleaned the filters emptied all the water by hand switched on the macheine and it has done it again. Please help
  • 868 Answers
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
Machine not starting, draining.
Drain pump has timed out, could be a blockage on the drain line kinked or twisted hose blocked drain pipe, try lowering the drain hose as flat to the floor in a bowl or bucket and drain as much water out as you can then re-position drain hose nto drain stand pipe and try starting a cyle just doing that may resolve your problem
Apr 02, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint dishwasher fdw60
the fault wasn't with the machine. we got new waste pipes put in and the conection for the dishwasher hose didn't have the hole for the water to release. thank you for your help
Jul 15, 2008 | Hotpoint Dishwashers
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
FDW60 Fast and Eco Lights
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
125 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
