Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Flash drivers what are flash drivers and what happens when installed in usb port
  • Anonymous Nov 09, 2008
    not him explore Windows from San Disk 2 GB Cruzer Micro
  • wr1921 Mar 13, 2009
    I received a 2GB USB Flash Driver from MicroCenter without any instructions. This is my first "stick" and I have no idea how to install and/or use it . Do I need a new driver?
    Thank you.
    Scholar:
  • 64 Answers
Hi clueless,
If you're using XP or Vista, most older flash devices will be recognized by Windows and the appropriate drivers automatically installed. If you're using a newer flash device or an older version of Windows, however, sometimes a driver is required for the system to be able to use it.
Check out this link and see if you can download a driver that will work for your specific device.
Ben
Posted on Mar 05, 2008
The driver, it is not on my computer
USB Flash Drivers are an automatic install and so should work out of the box. If they aren't then can you try another flash drive? Can you also try and use another known working device in that same USB port? Is it the USB port that is damaged? Does the PNY work in another computer?
Oct 29, 2014 | Acer Aspire 4530-5889 Notebook PC
Windows vista
There were several models made in the Classic format.
Early units had either Firewire or USB ports.
If USB...you would need an External CD Drive that plugs into the port on the player. Drivers would have to obtained from Apple at their web site and copied to a CD. Then a CD with the drivers would be inserted into a USB CD Drive and loaded on tot eh Player. The other solution is to Download the Drivers onto a computer, insert a FLASH Drive into the USB port on the computer, copy the drivers to the Flash Drive, and move the Flash drive over to the IPod's USB port. Copy the drivers or install from the Flash Drive.
Apr 03, 2014 | Apple iPod classic MP3 Player
Sir ! when i atteched pendrive from usb port in hp530 laptop give error usb unreconizable
This can happen if the proper driver for this device is not installed or that the USB stick is damaged. If proper driver is not installed go to control panel-hardware-device manager & locate the device and update/reinstall the driver. If it still does not work plug your USB stick on any other computer & if it works then format it once & try again on your laptop.
Nov 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
Oct 12, 2010 | Sony VAIO VGN-CR220E/P Notebook
I am not able to access the drive on my lap top, can you email me the driver.
USB flash drive doesnt require any driver to be installed. Please try this Flash driver on a different USB port or in a different computer to see if it the port or the computer or the flash drive which has issues
Aug 23, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I HAVE WINDOWS INSTALLED ..ITS COOL BUT IT WONT SEE MY EXTERNEL HARD DRIVE?
for some reason it happens that the power comes out from usb port is not enough to trigger the External Hdd on
if you have a long usb extension or using the front usb ports also it could happens (avoide them) .
Nov 18, 2009 | EliteGroup P4VMM2 Motherboard
Cannot be recognised on my USB ports
The CD supplied does not have drivers on it. This is a flash player so your PC should recognise it automaticaly.
If this is not happening, please try installing an MTP Porting Kit via the microsoft.com website.
Jul 14, 2009 | Samsung YP-S3JAB Digital Media Player
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Regards!
Jul 09, 2009 | Office Equipment & Supplies
How to connect USB NAS to D-Link DIR 655
if you update your router firmware to the most current you can use the usb port to connect to an external hard drive or flash drive but you have to install drivers on the computer you want to access it with also i believe only one person can access it at a time
Oct 25, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Usb ports
Check to see if your flash drive or printer needs drivers in order to work properly. If not, then it could be the drivers for the usb ports or you have faulty usb ports. They're supposed to catch it at the factory, but it happens from time to time on new machines.
Jun 20, 2008 | Toshiba Satellite A135 Notebook
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
126 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Alun Cox
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
