Question about LaCie Big Disk 500 GB Hard Drive
Drive making loud clicking sound when spinning up and won't mount
I am out of Lacie warranty and opened the case to see if I could swap out the drive...when I opened it there were two drives, both identical 250GB Hitachi Deskstars. Guess this is a RAID 0 unit. Anyway, I individually tested both drives and both make that loud click sound when booting up. They do not mount on my MAC desktop.
Can I get new drives and put them in? Do they have to be the same drives or can I get larger ones? I think with the hardware RAID 0 they have to be indentical to each other...
    Champion:
  • 331 Answers
HI Koberlin1:
Typically, RAID0 requires identical drives.(size) If you mix brands though; there may be subtle factors that cause problems. WD's 250GB might be a "251.2GB" vs. Hitachi might have a 245.44GB ..
As long as your close (in a PC) you should be fine. However, best practice would be to match the drives.
Keep in mind with enclosures: heat is the enemy. Plastic holds heat; and the next set of drives will die the same way. At TechRx, Inc. http://techrxgb.com I recommend aluminum or some type of metal for an enclosure.
Posted on Jul 23, 2010
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie Biggest s2s 2.5TB eSata RAID having trouble mounting. It comes up some times, but most of the time it does not mount. I was working with it in Snow Leopard, but got an error message at startup to...
It is time to check the WARRANTY status of the disk-drive.
If the warranty has not yet expired, exercise the warranty, to get it repaired/replaced, at minimal cost to you.
Otherwise, open the case, remove the "dying" disk-drive, buy a new, compatible, disk-drive, and "transplant" it into the case, to create a working external storage device.
Jan 21, 2011 | LaCie Biggest S2S (301050) 500 GB Hard...
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
The computer does not recognise the hard drive through USB port.
The "click" is a sign that the disk-drive is malfunctioning.
If it still is under warranty, exercise the warranty, and get it fixed/replaced.
Otherwise, open it up, remove the disk-drive, and take it to a computer-store, and ask them to sell you something compatible.
Install the new drive into your casing.
Jul 18, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Drive making a clicking noise and not mounting
Not good... Sounds like a hardware failure in the drive. That clicking sound is the solenoid inside the drive. Hope its under warranty.
Apr 27, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 1 t drive will not mount. previously worked fine for almost two years. used as pc backup drive on bootcamp side of macpro. Primary drive in computer has also failed (fantastic). drive does spin,...
Sounds as though the interface card, between the hard drive and connector panel at the rear has packed up. If it is out of warranty it is worth opening and connecting to a separate cable. You will most likely be lucky.
Mar 07, 2010 | LaCie (300770) 250 GB Hard Drive
External Hard drive clicking sound and unable to view contents of
First check the LaCie power supply. I have a D2 HARD DISK EXTREME 250GB model 300770 that had this exact problem. I swapped out the power supply for the higher wattage unit from LaCie and presto, the drive functioned properly. Not saying this will fix your problem but I have personally had this exact problem. If not take the drive and mount it in a PC IDE/EIDE disk slot and see if you can mount the drive and recover your data (points to LaCie controller problem). Note opening the drive invalidates your LaCie warranty. Also note the warranty on my drive was one years and had long since passed. If that does not work, your last alternative it to use a disk data recovery service but that is big $$$$s. Bon Chance!
Feb 20, 2009 | LaCie (300770) 250 GB Hard Drive
Drive is on, won't mount, buzzing
It does not sound good, the hard drive may be faulty or even the drive enclosure could be faulty.
Try thr following:-
1. Take the LaCie drive and connect it to another MAC, if it reads the drive, your in luck.
2. Dismantle the drive case and remove the hard drive and reconnect it again (a few times). The drive may need reseating to make proper electrical connection. Test it in your MAC.
3. The LaCie case could be faulty, remove the drive and insert it into another working LaCie drive case. Test it in your MAC.
4. If the hard drive is faulty, there are hard drive data recovery companies that can retrieve your data, but it will cost you an arm and a leg for their service.
In future I would not rely on a single device for backing up important data. You should get 2 LaCie drives or a dat tape drive plus a LaCie drive and/or burn the data on BlueRay disks.
You should also protect your computer and devices against lightning strikes, power outages/blackouts and power surges with an UPS (uninterruptable power supply), especially when you are editing, burning, copying/back up your data.
Jan 15, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie Big Disk 500 GB Hard Drive Logo
229 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
