Question about Ye Data (YD8V07) Internal Floppy Drive
Yamaha Keyboard I have a Yamaha SY77 keyboard, which has a 720k floppy drive built in. Unfortunately it's not working, so wanted to replace it. Can I use a 1.4mb drive instead? If so, how do I overcome the difference in the power connection type between the drives? (the 1.4 mb has a 4-pin power connector). Or does anyone know where I can obtain a replacement 720k floppy drive?
GOT A PROBLEM WITH ONE KEY THAT DOESNT RESPOND TO THE VELOCITY AS IT SHOULD WHAT THHAT COULD BE ??
Posted on Mar 05, 2010
Brand new SY77 drives are also available here. www.floppydrivesolutions.com
We supply all drives with a 90 day warranty.
Cheers
Posted on Mar 17, 2009
Soulcollecta,
How did you buy the floppy drive from Japan? Please forward me the web site or the contcat info.
Posted on Sep 15, 2008
Had a problem with my drive. Had to import another from Japan at a price - only to find the drive reads disks when it feels like it. Tired of bad disk error messages when they work perfectly fine.
Posted on May 20, 2008
  • Kyle Nish
    Kyle Nish Jan 11, 2014
    WASATCHAUCTIONS.COM FOR FLOPPY DRIVES. I HAVE MANY YAMAHA MODELS AVAIL, INCLUDING SY77
Short answer, no you can't. Replacement floppy drive can be bought here: http://hometown.aol.com/mishon66/Drives1.html
Posted on Apr 01, 2008
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
Model: PSR 620. The floppy drive is not working and needs to be replaced. Original floppy drive uses DS DD 720kb floppies. Where can I get a replacement drive? How much does it cost?
The replacement cost of these is prohibitive often greater than $200.
You should try to clean the heads in your drive and see if you can spot a mechanical problem. Clean the heads carefully with 91% isoprophyl alcohol and Tube Gauze on a tongue depressor. Be very careful.
Aug 09, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
Looking for assistance, 1.44k TO 720K format ( downgrading )
The 720 format is automatic the drive will detect from the 1.44 drive to the 720, it's backwards engineered.
Aug 26, 2009 | Mitsubishi Computers & Internet
Yamaha Keyboard SY77 has no power. I've tested with a multimeter the power button and all the fuses that share that same circuit board. All seems well. Any troubleshooting ideas from this point forward?...
Try finding the bridge rectifier which is the device that converts the incoming alternating current into direct current which powers the circuits. Test it using the diode test function with a multimeter if you have one and see what results you get. There may only be a voltage rectifier or just a series of back to back diodes but that is what you want to test. I don't at this point have a schematic or service manual for that keyboard. Hope this helps.
Aug 19, 2009 | Music
Yamaha SY77 Keyboard--getting no power at all. Opened it up and used multimeter to test switch, and all fuses that share the circuit board with the switch. Any flowchart for troubleshooting this? Thanks!
Try looking for the voltage rectifier or bridge diode that converts the A.C. supply into D.C. to power the circuits. Test it with your multimeter using the diode test function if you have one.Hope this helps.
Aug 19, 2009 | Yamaha Music
I need to replace my floppy drive on a yamaha psr 9000 keyboard
Why.. get a USB floppy.. if you go inside a PC and pull a wrong wire your PC will be toast. Get a USB floppy. Why are you using floppies anyway? Get a USB stick for $8, way less then a replacement floppy and much safer.
Jul 16, 2009 | Computers & Internet
I need a JU-253-403P floppy drive or equivalent
[International Portal Floppy Drive , www.ruanqu.net] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Mar 05, 2009 | Panasonic (JU257A607P) (JU257A607P)...
FD-235HF-7529
This drive supports Ready signal or Disk Change signal on pin 34 (RY34 or DC34), has a large number of jumpers for various settings, thus (unlike the standard 235HF drive which works in PCs only) this drive can used to replace a 720k drive on older computers such as Amstrad CPC/PCW or Commodore AMIGA.
Nov 03, 2008 | Teac (FD235HFC291/391) (FD235HFC291391)...
Epson smd349 floppy
Hi Elia, Could be a couple of things: -Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD. -The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk. -The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD. -The new, used drive could be damaged. -The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB. Let us know what happens and please don?t forget to rate the posting.
Jan 19, 2007 | Epson 1.44MB 3.5 Floppy Drive Floppy Drive
Ye Data (YD8V07) Internal Floppy Drive Logo
575 people viewed this question
Top Ye Data Computers & Internet Experts
David Payne
David Payne
Are you a Ye Data Computer and Internet Expert? Answer questions, earn points and help others
