Question about Brother HL 5250DN Laser Printer
HL 5250 dn
Printer is printing black on long edges of both sides of paper.
Any idea what is causing this?
Thanks
John
  • docgirl May 01, 2008
    I have black marks along one edge. I have cleaned the printer and changed the drum. Any suggestions?
  • printprobs May 14, 2008
    I have 2 HL 5250 printers. They are both printing a black line along the edge. I have changed the drum and toner cartridge on one of the
    and it did help. However, it is still printing black along the edge. Any Ideas? Also, I have cleaned the drum.
    Thanks,
    New Friend:
  • 159 Answers
First you most clean the printer carefully then you most change the drum unit
Posted on Mar 27, 2008
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
Printer HL 5250 DN. .
try putting a cardboard box under the exit point to catch the paper. This will stop it from going everywhere.
Sep 16, 2008 | Office Equipment & Supplies
Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Jul 24, 2008 | Brother HL 5250DN Laser Printer
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Brother 5250DN printer noise
    Check my solution here:
    http://www.fixya.com/support/t641678-paper_tray_noise
    Here's a solution for you with Brother HL 5250 D/DN/DNT
    Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
    so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
    DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
    Good luck to all.
    Nov 02, 2007 | Brother HL 5250DN Laser Printer
    Brother HL 5250DN Laser Printer Logo
    426 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
