Question about Dryers
Frigidaire dryer rear spindle
Can this be lubricated or only replaced
Frigidaire dryer (WCI Canada)
model MDEC216REW0
    Genius:
  • 1,019 Answers
This Should Be Lubricated, Providing The right Lube Is Used.
You need To grease The Bearings With A high Melting point Grease. Copperease Or Similar. ( I,m not sure What the Americans Use ) alternatively A little Vaseline ( Petroleum Jelly Should Do the Trick ) Always Works Wonders For Me :)
If The Bearing Race ( Holder ) Has Broken, Then A replacement Will be Necessary, This will involve A gear Puller Or similar to remove.
If the bearing is Grating Or grinding, lubricant is only a short term fix.
Mike @ Compurepair.
Posted on Feb 28, 2008
  • Mike Waldron Feb 28, 2008
    Thankyou For Using Fixya.
    I am glad i have resolved Your Problems Or Questions.
    Many Thanks mike @ compurepair.
Drum making noise
The rear of the drum rides on a ball. The ball sets on a plastic bearing filled with lubricant. Over time the lubricant goes away and the plastic deteriorates. As in my home movie. In my DIY channel is links to service videos showing how to replace the rear bearing Here is a quick vid I made of a dryer with a broken rear bearing:
https://www.youtube.com/watch?feature=player_embedded&v=wkog1i53T_k
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 14, 2013 | Frigidaire Dryers
I have a Frigidaire Stacker washer dryer that has no model number anywhere and a tub seal with numbers that I have been unable to cross reference.
John, check out http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=1084015&ModelNum=FEX831CS0&mfgModelNum=&ManufactureID=4&Selected=OMQBC08N&Position=5&mfg=Frigidaire&Type=&Mark=5r
Jun 02, 2012 | Frigidaire FEX831CS Top Load Stacked...
My dryer has a loud squeaking noise it is a frigidaire dryer model num AEQB6000ES2
Hello there and welcme to fixya
This is a fairly common problem with these dryers
please check each of the following you will probably have to remove the outer shell to get axcess to these parts listed below
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 23, 2011 | Frigidaire Dryers
Whats the voltage on a frigidaire Crown Dryer Model #FDEB23RGS1?
that depending where your at
in England/Canada its going to 208 volts
in the USA it will 240 volts
in other parts of the world it could be somewhere between 208 to 240 depending on what the standard is in that country
Sep 30, 2011 | Frigidaire Electric Dryer
The dryer has developed a hi pitch squeak. Does something need to be lubricated and how do I do it?
Usually the hi pitched squeal is either the belt slipping or the bearing. It the drum hesitates at start, then look at the belt as the culprit. But that sound unsually stops after the drum starts retating.
If it grind all the time it is probably the bearing http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dryer-Parts/Model-FSG748GFS0/1428/0151200/Y2704973/00002?blt=06&prst=&shdMod= ITEM 12.
If it is loud then I would replace the bearing and lubricate it well with lithium grease.
It isn't that hard to do but does require you to remove the front and top of the dryer, so I hope you are comfortable with that type of work.
Jun 19, 2011 | Frigidaire FSG748GF Dryer
My dryer is making a loud humming noise
your pump belt in motor to spindle were tilted or loose. or your motor need to replace coz i think your washing maybe is to old
Mar 02, 2010 | Frigidaire Dryers
Clothes get hung or catch in the dryer and buttons get torn off or the clothes sometimes get scorched. I have a 2 year old Frigidaire front loader. Model # LEQ2152EE0. Any advice -- other than buy a new...
I believe your problem is worn out drum glides. You should examine the drum to see if the paint is not worn off where the glides make contact. A loss of coating there will accelerate wear on the new replacement glides. Also the bearing at the rear of the drum should be inspected and replaced if worn, or re lubricated if serviceable. The bearing should be a simple ball and socket assembly.
May 19, 2009 | Frigidaire Dryers
Sqealing
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
May 12, 2009 | Dryers
Dryer makes a squeaking noise
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire dryer makes noise when it tumbles
"spindle" would seem to refer to the rear drum bearing but teflon would describe the front. Have they both been done? Usually when one is worn out the other isn't far behind. Check the idler arm/wheel for wear. Also motors make a sound when the bearings are bad
Jan 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
187 people viewed this question
Top Dryers Experts
Marvin
Marvin
