Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Heat Pump was repaired and then went out again
Heat pump would not work, repairman replaced and repaired a wire outside. Pump worked again until the middle of the night. I had the defrost board replaced last year, could this be it again? Repairman is coming again later, but am frustrated with this situation. Had to suffer through two cold nights and don't want another.
    Sergeant:
  • 288 Answers
Repairman fixed a wire? sounds a little vague. If the outside coil is covered with ice, then it may be the board. Most defrost boards have a test terminal on them. Touch something to the test posts and see if the reversing valve switches on and the unit starts defrosting. If nothing happens, then its the board. There could be much more things causing it not to work, but I need more info.
Posted on Mar 05, 2008
No heat from air heat unit
Heat pump will only work when outside temperature is above minus 13 celcius or 9 far. Efficiency at lower temperature lower very quickly, spend more energy than what it produce. Good quality machine or option will de-energize outside unit from operating. Wait until exterior temp get warmer and try again.
Jan 03, 2014 | Heating & Cooling
Heat pump will not turn on
I would call an expert, testing needs to be done, but based on what I have seen it may be the control board of the heat pump is defective.
Mar 24, 2017 | Heating & Cooling
Heat pump shut off 1 to 2 minutes, service yesterday for same problem told low on freon. Added freon, worked fine until it went thorugh first defrost, now back to same thing. Tech says compressor not...
It is possible that you have one or a combination of a few different problems here.
If your heat pump will not come on but the air handler works, the first thing you want to check is that the circuit breaker and disconnect for the heat pump are both on.
The next thing to check is that the heat pump is receiving a call for heat from the thermostat. If there is no call for heat at the heat pump, then your problem is most likely a low voltage issue. This could range from a failed thermostat to a low voltage wire that is bad.
If your heat pump has high voltage supplied and there is a call for heat present with no heat pump running, you are going to be isolating the problem to the heat pump itself. The problem could lie within any of the electrical components in the heat pump from a bad capacitor, a failed contactor, or a failed defrost control board.
Jan 07, 2010 | Carrier Heating & Cooling
I have a goodman ac/heat pump....worked fine last season...now only blows cold air, even in heat setting....help! thanx
Heat Pumps are not famous for being fast heaters. Give it some time to act. Is yours extracting heat from the air or from a water source. If from the outside air, consideration must be given to the temp of the outside air. It takes longer to warm as the temp outside drops.
Yours could be a different problem of course, but let it have a chance to work before you call the repairman.
Dec 12, 2009 | Goodman CLQ36AR49 Air Conditioner
I have a Rudd ubha and have been using the emergency heat for a couple weeks because the aux. heat won't work. Now I need the A.C. but the unit outside won't turn on. We replaced the control panal and it...
Did you replace the defrost board out in the outside unit? Or did you replace the control board just on the airhandler? You need to check if the board outside is functioning. Also, put the unit in cool and check to see if the outside unit is being called to come on. What could of happened is the unit was the compressor went out and that's why it didn't work in Aux. and only in emergency. I would just recommend checking the outside for issues since the inside unit is operating in emer. It could possibly be the tstat also. Just buy a tstat for a heat pump and follow the instructions. The key is to label your wires with what color is going to what terminal (r,w,g,o,y etc...) and then use the new tstat instructions. Better yet, buy the same brand t-stat. Hope this helps.
Apr 04, 2009 | Ruud UBHC Air Conditioner
Air conditioner not working
If they removed the compressor (gas pump) the wires would be disconnected so that it could not possibly be started. With the gas pump removed it is not meant to be restarted until the proper repairs are completed.
Jun 04, 2008 | Heating & Cooling
Intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Nov 28, 2007 | Heating & Cooling
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
108 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
