Question about Meiko FV 40.2 Dishwasher
Dishwasher fix our meiko fv 40.2 stops running and states either err 111 or error 302 at times. any aswers
  • Anonymous Mar 20, 2014
    dishwasher was working find then error 301 shows on display board
    Problem Solver:
  • 11 Answers
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Posted on May 10, 2008
  • Kenneth Viel Oct 22, 2011
    Oh yeah in the back of some meikos the is a plastic cap round with a Allen key spot the middle and a small hole from time to time romove that cap. Behind it you will find a rubber piece. That has a flap on it clean that and put it back in . It stops unit from draining. A 5 min fix to an annoying intermitten problem
Usually with the 111 code I find the pump is normally leaking. But be a few reasons. Remove the bottom tray and empty water and try and locate leak or if float switch is bad
Posted on Oct 22, 2011
Ordered parts through dist/ expensive
Posted on Oct 13, 2011
Meiko 80.2 code 111 is there a quick fix to this problem
this code is usually an indication of water leaking internally where the motors are located. Needs to be found and stopped.
Jul 14, 2017 | Meiko Dishwashers
What does error 111 mean in MEIKO FV 40.2 Glass washer?
In most cases, there is a water leak inside the machine and water is dripping in the lower level where the motors are located.
Mar 30, 2017 | Meiko Dishwashers
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
May 26, 2011 | Meiko FV 40.2 Dishwasher
Error 302
Check the screen and drain line for clogs or kinks. If that's not the problem, then the drain pump is faulty.
May 13, 2011 | Meiko FV 40.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
Error 111 meiko dr80.2
it's water leakage inside the machine(or)water leakage switch defective.
Jun 20, 2009 | Meiko DV 80.2 Dishwasher
Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
3,058 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
