Question about Nokia N95 Cellular Phone
My N95 won't switch on
My N95 was switched on earlier today left on my desk at work. Came back to it to check for messages and it had switched itself off. It won't turn back on, and if you connect it to a charger it doesn't charge. If it knackered (if so I need to get in contact with 3 as it is only 3 months old!), or is there some way to reset it?
Cheers
I tried to update my N95 phone and it went blank now it would not come back on what to do
Posted on Apr 30, 2009
    Brigadier General:
  • 7,752 Answers
The only way would be to get the phone service but seeing that is it still a new mobile , take it back to the store that you bought it from and have them replace it or fix it for you.
Posted on Feb 29, 2008
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
My Fisher and Paykel smartdrive 9 PRIDE 5.5 washing machine won't fill on any setting. Worked yesterday but not today! The water starts/stops a few times until error light message and constant beeping...
Sounds like you have described this fault.
43.(00101011) Phase 1 to 6 - OOB Switch Fault The Motor Control Module has found that the signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Primary Source: Mechanical.
Action: 1.Check that the out of balance switch is free to move.
2.Check that no harnesses are blocking switch movement.
3.Check that the switch operates correctly when activated. Replace the switch if suspect. 4.If the out of balance micro switch shows signs of corrosion, replace the switch and switch harness, and fit a condensation kit to the console area if not incorporated in the top deck.
5.Check that the SmartDrive is level and also that the bias spring is in place.
Secondary Source: Wiring.
Action: Check the harness to the out of balance switch is connected correctly. The terminals should be connected to the normally closed position. If the harness terminals show signs of corrosion, then fit a new harness and switch.
The switch is located under the main computer. To get it out first unplug machine from the wall, then you will see two screws on the top back of display console take them out and remove console. Now you should see the main computer dissconect and remove, once out you can now get at the out of balance switch. Carefully remove it by pushing the tabs back one at a time again be very careful here as the tabs can break very easily. Once off unplug it from the wiring loom and then source yourself a new one.
Sep 02, 2011 | Fisher and Paykel (IWL12)
Nokia n95 doesnt let me send tx text messages
NOKIA N95 YOU HAVE GIVE TO NEW VERSION MOBILE SOFTWARE
Aug 22, 2009 | Nokia N95 Cellular Phone
Message says back door ajar plus it only locks manually
it is one of the door switches you can check them by unpluging them on at a time and jumping a wire from one side of the harness to the other to complete the loop then you will find the bad switch
Aug 10, 2009 | 1999 Cadillac Seville
My Nokia N95 8gb has been wiped and also the screen is black
you'd best be off replacing the lcd screen of your phone if the illuminator behind the screen is not working.
replace the flex cable as well as there seems this seems to be a problem with phones that have dual-slide features.
cheers.
Jul 06, 2009 | Nokia N95 Smartphone
2001 Montana heated seats not working Fuses good. Panel switches light up... no heat
check for power at connection under seat. If you have power, heated seat grid in the seat itself has burned out.
Dec 15, 2008 | Pontiac Montana Cars & Trucks
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
My nokia n95 switches itself off
when a nokia n95 switches off and on, all you have to do is put a sim that doesnt work anymore then you have to switch the n95 on and wait for 30 minutes, then the n95 will stop from on and off, the laguage will be set to france mode..
Apr 12, 2008 | Nokia N95 Cellular Phone
Wrong letter shows up
looks like you have turned ON the dictionary, switch it off.
while you are in the create message folder keep pressing # key until you see "abc" or 'ABC' on the top left corner of your display. this would mean your dictionary is off
Nov 01, 2007 | Nokia N95 Cellular Phone
Mobile Acting Strange
Have you tried downloading the Nokia software updater from the nokia website? After you download this, backup your phone. Then plug it in and it will update the firmware. This might help.
Aug 23, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
101 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
