Failing CRT TV
Have a Goodmans widescreen CRT TV. The set switches on, the picture starts to narrow in width at the centre line of the screen, and after a couple of minutes it starts to smoke a little. Any ideas what might be wrong? Is it worth repairing?
    Scholar:
  • 133 Answers
Could be a couple of circuits that are failing. Something in the horizontal or the damping sections . Maybe a IC or a cap that is shorting out . If it had good brightness and good color it might be worth saving . If any of those two might be weak it might be time to scrap it . If you take it to your local repair center ask them what there estimate charge is if you don't get it fixed , as then it might be worth getting it checked out. Good luck
Posted on Feb 28, 2008
I AM GETTING BRIGHT HORIZONTAL LINE IN CENTER OF THE PICTURE TUBE.& AND ALSO SCREEN WIDTH IS MORE
Sounds as if you have an older model T.V that still use Light tubes to produce the picture,both conditions are indicators that the picture tube is failing. Not many TV repair shops around anymore,since the price of Good quality TV's are realetively inexpensive. may need to buy another.the tubes themselves are very hard to find.
Jun 07, 2012 | Televison & Video
Picture too big so faces long and narrow, how must i zoom out to make pic smaller
If the image is tall and thin, then you've likely got your TV set to widescreen mode when it's not a widescreen TV. In your TV's menu, there should be an option to change between widescreen and normal, or one called "Aspect Ratio" and it'll give options like 16:9 and 4:3, change that to 4:3 if that's the option it gives you.
Jun 05, 2010 | Televison & Video
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
CRT 28" widescreen TV, has thin bright line horizontally across, centre of screen and sound. There is no proper picture.
You have sent me an e mail asking me if I have solved the problem. I sent you the e mail telling you what the problem was because you advertised that you could solve the problem. Not write to me a day later asking me if I had fixed it. If I could have fixed it I wouldn't have written to you asking for a solution to the problem.
Nov 02, 2009 | Televison & Video
My goodmans TV has changed it's picture to a goldfish bowl effect. It has not got widescreen settings as it is over 10 years old. I have tried turning the set off and on but it has not changed it? Any...
This sounds like what is referred to as an East-West fault. This is caused by initaillly a poor solder connection, but then can cause a capacitor, a diode and occassionally the E-W transistor to fail. You will need to take it to a repair centre.
Mar 28, 2009 | Goodmans Televison & Video
Wide screen adjustment does not hold keeps going to default narrow screen
Most analogue TV's do this because the analogue signal has no way to tell the TV that its a widescreen picture.
European TV's that use scart cables have a switching pin on the cable so the digital set top box can tell the TV that the picture is widescreen.
If you're in the US or down under this info wont be much help though.
Hope this helps
Andy
Jun 26, 2008 | Televison & Video
TV SCREEN PICTURE SMALLER
Yes you have a problem I'm afraid in the pincussion or horizontal width circuit. These circuits usually have alot of high voltage in them and is not a safe place to be experiementing around with. Most of the time, with a problem like this, there are bad capacitors or a correction transistor has failed. If the set is over a few years buy a new one. Good Luck
Jun 04, 2007 | Bush 5693D 24" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
