My batteris died i change the batteries now it dont want to work
    Scholar:
  • 133 Answers
Did the batteries leak ? If so clean off the contacts with small file and clean the posts . If not sometimes buttons get pushed in and the remote will not respond . thus draining the batteries. If that is not it take it to your local shop and they should have a little tester card that will show if your is putting out a signal. takes less than a minute for them to check. Also i have to ask as i have seen this a few times make sure the batteries were installed correctly . Good luck
Posted on Feb 28, 2008
Power issues with 97 honda accord lx
is there any light left on boot door ect is the radio left on making sure you turn that off before turning car off get charging relays checked as if these dont work if they have them the battery will drain as the alternator wont charge it also if buying a new battery spend a bit more on a desent one as the cheaper ones dont always last plus the new one could be duff as well it does happen quite a lot hope this helps ivan
Oct 02, 2012 | Honda Accord Cars & Trucks
I changed my pontiac car batteries but the problem ocured i mitaked in + and - battery and i do it revers and now my car dont working
Bad things happen to electronics when you do that. Nobody died, so there is that aspect of it.
Does anything work when you turn on the ignition ?
Sep 19, 2012 | Cars & Trucks
My mouse batteries died and since then hasnt worked.
check your batterys with a flashlight after that push the buton on your recever. then push the keyboad reset and last do the mouse. if that don't do it switch and do the mouse first then the key board. keep close to the recever it works better
Aug 04, 2009 | Lenovo Mini Wireless Laser N10 Mouse
Speedometer & odometer not working after dead battery replacment
Remove the - (Negative) battery lead and wait for a few seconds. the refit BUT DONT LET the terminal arc keep it firmly pressed on while tightening. It seem as if this may have happened when you fitted the new battery as any rapid on off power to the management system will scramble it. You also dont say if you have driven it far as some times after a battery change depending on management system fitted around 20 miles before system workks out settings lost when power removed (happens after a sensor change aswell) hope this helps.
Jul 08, 2009 | 1997 Ford Escort
Hw to unlock samsung d500
THEY MAY BE A TEMPORY FIX,BUT WHEN THE BATTERY DIES YOU HAVE TO PUT THE CODE IN AGAIN,SO TRY IT IF YOU LIKE,IT WORKS ON MOST SAMSUNG PHONES.
PLACE THE SIM CARD YOU WANT TO USE IN THE PHONE,THE KEY IN *#9998*3323#,THEN SCROLL DOWN TO OPTION 7 AND PRESS EXIT ,IF THAT DONT WORK THEN TRY SELECT.ONCE YOU PRESS EXIT IT MAY TAKE 20SECONDS THEN THE PHONE SHOULD RESTART AND BE ON THE NETWORK YOU WANT.IT DONT CHANGE THE NETWORK PERMENTLY BUT DOES WORK FOR TEMP USEAGE.
REMEMBER ONCE BATTERY DIES YOU WILL NEED TO START AGAIN.
GOODLUCK
Feb 21, 2009 | Samsung SGH-U600
How to get pictures
go to a store that has the machine where you can order a CD of your pictures rather than getting prints. Walgreens, Walmart, etc...
Its a good idea to buy a card reader for your type of card so you dont have to use up battery power while uploading photos to your computer. It saves a lot in batteries.
As for your battery, if you have rechargeables, you should always keep spares and only recharge when battery completely dies, dont charge just because you used it, only when it dies....this will prolong the life of your battery/batteries.
Julie
Jan 09, 2009 | Jazz DV-179 Digital Camera
How to Change battery Diesel DZ7040
dont do it yourself it will invalidate the warranty bring it back to the shop the should replace the battery free of charge. it might be more than the battery. if this helps please rate. joe
Oct 04, 2008 | Diesel Audio Diesel Watch
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
