The "EP" error code on your refrigerator's display typically indicates a problem with the water pressure entering the ice maker. This can be caused by a few different issues, including:
- Clogged water filter: If the water filter is clogged, it can reduce the water pressure entering the ice maker, causing the EP error code. Try replacing the water filter with a new one.
- Restricted water supply line: If the water supply line is kinked or otherwise restricted, it can reduce the water pressure and cause the EP error code. Check the water supply line to make sure it is free of any kinks or restrictions.
- Low water pressure: If the water pressure to your home is low, it can cause the EP error code. Check with your local water provider to see if there are any known issues with low water pressure in your area.
- Ice maker valve: The water inlet valve that supplies water to the ice maker may be faulty. If the valve is not opening or closing properly, it can cause the EP error code. You may need to have the valve replaced by a professional.
If you are unable to resolve the issue on your own, it may be best to contact a professional appliance repair service for assistance.
