Question about Sharp 27H-S60 TV
Sharp 27H-S60 TV problem
I am looking for a manual on above TV. Or soultion for TV that is dark - can not find remote that came with it, our cable supplied a universal remote. There is no brightness etc on cable remote.
  • ramcnitt Feb 23, 2009
    Where is the flyback screen control on the tv? I see nothing but a rounded back and nothing to flip up.
I bought a replacement remote from ebay which controls video, changes channels, turns cc on and off etc...everything except turning the SAP off which is stuck on but I use my dvd player/vcr unit and change the channels thru it with no issues
Posted on Feb 27, 2009
  • 129 Answers
Good day.
With regards to the brigthness issue, you can adjust the brightness control of the your unit through the Screen control located along the flyback of your TV.
chris
Posted on Mar 11, 2008
Sharp 27h-s60 turns on but not tunning into any stations
Maybe the program was erased. go to menu and press the auto search program,,, check the bad solders around the tuner. or its possible that the tuner is bad.
Jun 24, 2014 | Sharp 27H-S60 TV
Hi I have a sharp 27H S60, has worked fine for many years. Now, I get fine sound but no picture. When it is first turned on I get a thick white line in the center of the screen for a second, then it is...
The problem is a vertical deflection issue, it means the picture from top to bottom has collapsed. The set will require two or three capacitors and an ic and it is quite fixable.
Feb 07, 2011 | Sharp 27H-S60 TV
Missing resistor
1.8 ohms at 2W
Dan
Sep 23, 2008 | Sharp 27H-S60 TV
Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
May 22, 2008 | Sharp 27H-S60 TV
Cant turn sap off missing sound on some channels
Hmmm, you'll need that original, there. See if you can find one, and maybe even just borrow one to get what you're after...accordianman
Feb 09, 2008 | Sharp 27H-S60 TV
No power
Solder any / all bad solder connects.While doing that,Look for
overheated areas in power circuits,caused by bad capacitors,
resulting in burnt/open resistors,shorted diodes,etc,.........T.
Nov 13, 2007 | Sharp 27H-S60 TV
Sharp 27G-S60 TV analog or digital?
Call 1-800-237-4277 1-800-BE SHARP
FAX 1-630-378-9981.................................................
Oct 21, 2007 | Sharp 27H-S60 TV
Sharp model 27H-S60
on your remote that you bought there should be a button that says code search hold that button untill it lights up then press tv then put in the codes depneding on the model either it ahould automaticly put it in or press enter. Repeat untill it works
Oct 20, 2007 | Sharp 27H-S60 TV
Cable/air
you will need to use your factory remote to do this function.
Oct 14, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
311 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
