Question about Sony TCW475 Single Dual Cassette Deck
Tape is stuck in the player
One cassette player works, the other one froze up with the tape in it. It will not play, rewind, fast forward or eject. How do I go about fixing this? Not a techie so detail would be most appreciated.
  • Molly West Feb 28, 2008
    I cannot see the answer- how do I see it?
    Mattozan, your answer is definately more useful, so thank you very much. The manual is wonderful!! When I click on the little diamonds to rate you nothing happens, and I cant figure out how to un-rate Mr Smilemaker. I feel like an idiot....
    Master:
  • 555 Answers
A manual for your unit can be found here.
It sounds like an electrical fault in the unit has left that side's motor without power.
Try powering off the tape deck and unplugging it, then waiting for an hour or so. Re-plug and power it back on and see if function has been restored.
Posted on Feb 28, 2008
  • Matt Jurach
    Matt Jurach Feb 28, 2008
    smilemaker did not submit an answer to you. But by rating his response, you have awarded him $5 for a FixYa answer.
    Perhaps you can change your rating to a more helpful answer? Like mine?
  • Matt Jurach
    It's OK. I'm new to this service too, and parts of it are pretty confusing. I've never seen a question from the asker's side, only from the answerer's side, so I don't quite know how it looks.
    In our little payment guide it says that "A notification about every new solution is sent to the asker. Once the
    user accepts a proposed solution, the thread is then locked and the
    expert is rewarded with up to $5.00."
    Don't worry about it. I'm glad the manual is helpful, though it might not be enough for this problem.
  • 790 Answers
HELLO!!
  • Kanth raj
    Kanth raj Feb 28, 2008
    Hello am really sorry for my mistake anyways have abused it myself to fixya experts ...don worry !!!
  • Kanth raj
    I guess the capstan belt has thrown and it require a new belt
    fitted. the transport depends on capstan rotation to engage play. a
    separate reel motor operates forward or rewind and take up funtions
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Buick 2002 I have a cassette tape stuck in the
fast forward cassette then rewind till it stops then it should be able to eject
Mar 13, 2009 | Car Audio & Video
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Sony TCW475 Single Dual Cassette Deck Logo
200 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
