Question about Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor
The intergrated speakers dont work..on my montor anymore..
Lost driver due to virus and system restore. Can't find due to age of monitor,manufactored in 2002. Would appreciate any help to get driver so speakers will work again. model 780 and the product # LT765 Thank you.
  • Jolly174 Mar 07, 2008
    My monitor doesn't have speaker cables that plug into the computer. Does it use an intergrated cable, or does it not even have speakers?
  • 28 Answers
What is the sound card in your computer? I am pretty sure your speakers won't require drivers. Your sound card in your computer is what needs installed, I am guessing.
Posted on Mar 06, 2008
No sound,no speaker icon shown in the system tray
check out if you have install your sound driver properly...
if you dont have driver cd you can download it...
how this problem actually happens??
if it happen after you scan a virus... then your antivirus had delete some imp register,,,for this you can undo or restore through your antivirus...
or if it is after formatting your pc then ofcourse you need driver...
before it was working but after restarting it happen...that means it may be the problem of unproper shutdown or virus prob.. for this try this out...
system restore:
  1. goto start>all program>accessories>system tool>system restore
  2. system restore will open
    "select restore my computer" click next.
  3. one calender will open,,, now select any checkpoint (ie. day before the problem occur
hope it works..
any problem contact us...our service is 7weeks 24hrs anytime..
thank you,,
Nov 30, 2010 | Computers & Internet
I have speakers built into my monitor but since changing from vista to xp they dont seem to work anymore im so confused and dont know what the hell to do because before thet they were working brilliantly
well the reason for it not working is becausethe windows lost the speaker's driver so what you need to do is to re-install the driver of the speaker.
Jun 09, 2010 | Dell Audio Players & Recorders
External monitor wont work after system reeboot
Try using pupppylinux livecd this will allow your to boot into linux and probably view everything on the external monitor. Then you could install puppylinux to hard disc and bingo you have a working pc again, you could even rescue data off the drive this way. When booting off puppy , it wont make any significant change to your harddisc. and you can access the hdd if needed.
Mar 26, 2010 | Computers & Internet
The speakers are intergrated in to the monitor and don't seem t.
First, find out if the speakers or audio is working properly. At your PC menu, left click Setting, Control
Panel, and Add hardware. Click the add hardware wizard and just follow the instruction until you will find all the installed hardware of your PC. Click at the Audio, and the sound driver of your PC to find if these are working properly. Assuming that this are working
properly, test the audio output of your PC by putting
in another set of speaker (borrowed or otherwise).
If you hear the sound, then it is a connection problem. The wire to the speaker could be broken, or
the speaker itself. Under this condition, it is your
option to open up your monitor and test the speakers.
Or to just buy a new set of speakers. Unless you
are familiar with handling an open monitor, you may
go ahead with opening the monitor Otherwise, it is
wiser to buy the speakers which is much cheaper
than a monitor that could accidentally get damage.
Nov 29, 2009 | NEC Speaker Wire Computer Speakers
System was restored due to virus/worm. Speakers
check http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4700&os=WW1&osl=en&catid=&impid=
if you have a dell dimension 4700 like it shows this is the page with allthe drivers you can get.
you want to click 'Audio' -> 'download now' and then install that audio driver, that should fix the problem
Apr 16, 2009 | Dell Dimension 4700 PC Desktop
Sound driver
Email the manufactor, ask for restore driver cd, may cost around $20.
Apr 09, 2008 | Computers & Internet
Speakers
Sounds like you need to re-install your sound drivers.
Apr 09, 2008 | Compaq FP 7317 17" LCD Monitor
SPEAKERS
Hi Jonathan,
Pls check if the cables are connected to the right port.
Also check the monitor volume settings.
Pls check with a set of powered speakers.
Pls run dxdiag from Run in Start menu if you are using windows.
Also you can check for any issued with the drivers or any driver updates.
Pls try a system restore also if none of the above steps work.
Jan 23, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computer problem
Acer has a web site where you can download software for your Aspire 5580. Your Laptop has a intergrated sound chip, XP may not have installed the driver for your speaker/sound system. You can try downloading at the link below (page 2),"
Audio driver v.5.10.0.5273", or you can install your audio driver from the restore CD that came with the notebook. No restore CD's! This site has everything installed onto your notebook.
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205580.pdf?CFID=5450003&CFTOKEN=70459540
Dec 13, 2007 | Audio Players & Recorders
Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor Logo
144 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
