Question about Acer Aspire™ T180 PC Desktop
Input not supported
I got a 19" widescreen monitor that keeps saying input not supported. I have had this cpu 4 about 4 months. My resolution is on 1280 by 1024 rite now. i can go as far as 2048 by 1536 which is great. i notice the difference in clearity and am hoping someone knows what 2 do.
  • acamp1989 Mar 02, 2008
    tI went to refresh rate and it only has "use hardware default setting". Should i reboot my computer?
  • 113 Answers
In display properties under advanced, lower your refresh rate to 60 hertz. Then go up until it no longer supports it then back off a notch.
Posted on Mar 01, 2008
Screen flashed and stopped displaying widescreen
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
Oct 22, 2012 | LG W1934S-BN 19" Monitor
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
Dell GX260 has distorted video on Dell 19" widescreen. Circles turn into ovals.
Most likely the Display Resolution is not set to a 16:9 display aspect ratio (1366 x 768 for example) if you use a 4:3 ratio on a widescreen, then everything is distorted. Make sure the display is set to the optimal resolution You can look up you monitor's Optimal Resolution here:
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~subcat=54&~cat=3
Jun 16, 2010 | Dell OptiPlex GX260 PC Desktop
Monitor say Input not supported. What does this
Your graphics card is set to a resolution of refresh rate that your monitor cannot handle, This can sometimes be one of the normal settings - there is not much you can do. Each monitor has a native resolution which the monitor should always be set at yours is:- 1280X1024
Nov 03, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
Screen says mode not supported h:53.4khz v;84.ghz
You should reboot your computer. Immediately after you see the BIOS splash screen (Dell, Acer, HP, etc...) start pressing the F8 key 2 times every second. If you're quick enough, you'll get the Windows boot menu. When you see the menu, select "VGA Mode". This will boot Windows with minimal video settings which are compatible with all modern monitors.
Once Windows loads, right click on the desktop, select Properties, go to the Settings tab, and begin sliding the resolution bar up from 800x600 and clicking Apply. After each change, it'll ask you if you want to keep the settings. If you can still see the screen, click Yes. If you get to a setting where your monitor goes black and says "mode not supported", then wait 15 seconds and it'll revert to the last mode that worked. Leave it there.
Here are some typical resolutions for monitors:
17" = 1280x1024
19" = 1280x1024
19" widescreen = 1440x900
21" = 1600x1200
24" = 1920x1200
Hope this helps!
May 16, 2009 | HP Compaq d530 CMT Intel Desktop PC -...
Make sure Resolution is 1440 x 900......
hello,
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
ramesh
Nov 29, 2008 | Envision 19" Widescreen Flat Panel LCD...
"input not supported"
what you may need to do is find an accepted screen resolution, as your screen is 19" widescreen and your notebook will be set for a normal monitor display, so either try the auto button on the screen or look at the properties of your graphics card om the notebook to find supported screen resolutions for extended displays.
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer Aspire™ T180 PC Desktop Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
