Question about Estate TEDX640JQ Electric Dryer
Estate dryer STOPPED BLOWING HOT AIR.
  • 5,911 Answers
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
Now, if your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
Posted on Feb 28, 2008
The pulley come off and i don't know where it goes
Posted on Mar 22, 2011
  • 30 Answers
5 most likely culprits:
From most likely to least likely:
1. Thermal Fuse ($10-$20 at local appliance parts store/Sears Parts)
2. Thermal Cut-Off
3. Thermostat
4. Heating Element*
5. Ignitor (FOR GAS DRYERS ONLY)
*Cannot be tested with an Ohm meter. Must inspect to make sure there is no damage along the coils of the element. All other parts CAN be tested with an Ohm meter.
Posted on Mar 08, 2008
My Estate Electric dryer blows no heat. What element do I need Estate TEDS740PQ1
Posted on Apr 14, 2009
The dryer hose fills with water, the lint trap never catches anything and the roof of the dryer gets hot but the clothes wont get dry. Any ideas? Thx
It sounds like you have no fan blowing. OR the vent is completely blocked so no air flow.
You could check fan by disconnecting the vent hose in back, and turn dryer on. Is is blowing a good volume of air? If so then you need to look at the vent. Any critter build a home in there? etc..
If there is no significant air blowing from the vent, you'll need to figure out why the fan is not blowing.
It's possible the fan is turning but is choked up and unable to move the air.
Perhaps the fan is bad, or there is a capacitor gone bad,.
That's as far as I can go from here.
Others may assist you further..
Dec 04, 2010 | Estate TEDS840JQ Electric Dryer
New heating element not working
You should check to see if the "high limit switch is burned out. Some models/Brands have 2. It should be on the outside casing of the heating element.
Apr 30, 2010 | Estate EED4100SQ Electric Dryer
My dryer runs but has no hot air and won't turn itself off.
you might need to replace the heating element
Sep 05, 2009 | Kenmore 63942 Dryer
Electric dryer not blowing hot air
Sounds like the heating element is not working, make sure you are getting 220 volts to the recptical. Let us know if that did the trick. If not let us know thankyou
Mar 15, 2009 | Dryers
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Nov 05, 2008 | Kenmore 63942 Dryer
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Estate TEDX640JQ Electric Dryer Logo
432 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
