Question about Mitsubishi WS-55805 55" Rear Projection Television
Trouble shooting 55" mitsubish hdtv 1080....
I just bought t.v from a friend a few weeks ago. Everything was working fine until yesterday. For some odd reason the picture became as if i was seeing double. so i turned the t.v set off and tried to reboot. And it wouldn't turn on. The green light would appear and there was a weird click'n sound when I pressed the power button. I've asked around several of times and others say it might be the fuse but I need a second opinion. PLEASE HELP IF ANY INFO. THANKS
  • 59 Answers
The clicking noise could be the lamp. It could be bad or just needs to be reseated to the ballast. Take the lamp out and look at the bulb. If it is not clear looking, it is bad and needs replaced. If it looks clear not smoking white, just make sure it is seated correctly to the ballast. After you have reseated the lamp (if it is good) and the ballast is still clicking when you turn on the TV, then your ballast is bad and needs replaced. You may also want to check the color wheel because it too will click if it is broken. Just take the top off the engine beside the lamp and look inside. The color wheel is made of glass and you can see if it is broken. If so it needs to be replaced.
Posted on Mar 23, 2008
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture keeps alternating between HDMI1 "blank screen" and cable
try the lead in another slot and even another lead, if problem persists demand an engineer comes out.
Jul 31, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Hc-p4752w will not turn on.
you will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
May 29, 2008 | Samsung HC-P4752W 47" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
WILL NOT TURN ON
Did you say you got it from an X friend? LOL Sorry, its not funny, It obviously didn't like being moved. Sounds like solder problem in the power supply somewhere, hunt round locally for a good shop. (probably a few hundred dollars to get fixed.)
Aug 01, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
