Question about Philips PET702 Portable DVD Player
2 month old Phillips portable DVD player can't get past loading
Screen works, opened it up, the lens is clean, the lens carraige moves, but it won't get past the loading stage. (My son did throw up on it, so when it wouldn't get past the loading stage, I took it apart and everthing looks fine inside) Is there some reset button or something? some little thing? :( )
I'm grateful for any helpful suggestions.
Dee
  • Anonymous Mar 23, 2008
    I HAVE A SAME LOADING PROBLEM
    I TESTED A DISK CLEANER ON IT AND IT WORKED BUT IT STILL DOESN'T LOAD OTHER CD'S
  • Maggie319 Mar 28, 2008
    I have the same problem. It was working, my daughter wanted a different movie, so I changed discs. Now movies don't load. The cleaner cd loaded and ran, but still no Wiggles. HELP!
  • 476 Answers
Clean the laser lens gently with a foam cleaner using a cotton swab & leave to dry.
Also, with the power off, gently push the laser lenscarriage all the way outwards from the centre. There may be debris on the tracks.
Posted on Feb 29, 2008
The DVD player won't read the DVD. Can I purchase a new eye for the unit?
try cleaning the optical lens of the player.you can use a cd cleaner it is available at electronics shops.or you can maually clean the lens by opening the cover and wipe the lens with a cotton buds moistened with an rubbing alcohol
Jun 27, 2012 | Insignia Televison & Video
My dvd player works but just keeps saying "loading" on the home screen.
hello,
the reason your dvd palyer keeps saying loading without working is that the laser or lens is weak or dirty.
the solution is for youto
1. use a lens cleaner to clean the lens,
2. replace the lens,
to replace the lens,
1.get a replacement lens,
2. unscrew the player from underneath,
3. carefully move the board that you will see, it is like a panel,
4. gently unscrew and remove the lens, and replace it with the new lens you got for replacement.
5. carefully place the panel or board back,
6. couple it back together,
test with a DVD disc.
take care
Jun 11, 2010 | Audiovox D1708 Portable DVD Player
My Phillips DVD player does not read any dvd's and is not playing. Just stays on the loading screen
If your DVD player is older then 3-4 years is possible to have dust on the reading lens. Best way to clean very well the lens , is to open the player and clean manually with cotton stick wet in alcohol. Try to not push very hard on the lens when you clean it .
Feb 28, 2010 | Philips DVP1013/37 DVD Player
Our only one month old portable insignia dvd player will not read any dvd...get message stating "loading" or no disc...Please advise
try clean the lens with cotton buds gently/smoothly...try audio cd or vcd to play if it will play and not playing if the disc is dvd...lens for replacement partially burnt
Jan 03, 2010 | Insignia I-PD720 Portable DVD Player
Portable dvd player says loading but wont play
This is because of the problem with the pickup unit.. Your try to clean the lens with the help of the lens cleaner, if the problem still persist then open the panel, clean and apply the white grease on the moving parts of the Disk reader.
Caution always remove the main power before open the panel.
Jul 28, 2009 | Coby TF-DVD7005 Portable DVD Player
Attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
Jul 03, 2009 | RCA DRC629N Portable DVD Player
Phillips Portable dvd PET824 won't play dvd; no picture or sound
you can try moving the laser lens that reads the dvd's just don't touch the lens just move that little square it's attached. all you have to do is move it back or forth just a little and leave it and try the cd and if that don't work just keep on moving it around until it reads. it'll work i had that problem on my dvd player and my playstation.
May 02, 2009 | Audiovox D1708 Portable DVD Player
Problem loading disc
just open the loader and replace the lense.
Jul 23, 2008 | Dynex DX-PDVD7 Portable DVD Player
Error code on Panasonic LS50 portable DVD player
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. i pointed out that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
Nov 25, 2007 | Panasonic DVD-LS50 Portable DVD Player
Philips PET702 Portable DVD Player Logo
232 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
