Question about Harman Kardon AVR 630 Receiver
Powering off by it's self...
After about a minute of turning on my receiver - it will shut off by itself...HELP!!
    Genius:
  • 1,175 Answers
It sounds like an overload/no load problem.
Are ALL the speakers connected? to the right places?
If the amplifier section doesnt "See" what it needs, it will shut off.
If all connections are good and it shuts off still take it to a tech who knows stereo. Doesnt have to be an authorized HK guy either
Posted on Feb 28, 2008
When I turn my system on, it waits 5 seconds, says "PROT" then shuts itself off.
There could be a short circuit in one of the speakers. This would cause high current flow thru the amplifier and result in self-protect. Disconnect all speakers from the unit and try powering up again. If there is no PROT, then reconnect speakers one by one until fault found or all speakers are reconnected.
Oct 04, 2015 | Samsung Ht- C550 5.1 Channel 1000 Watt...
Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics ledstiles@hotmail.com
Apr 23, 2010 | Audio Players & Recorders
Unit powers itself down
does it do this when on battery mode?
or when its plugged in?
i found they do tend to drain quicker the older it gets and that just because of a week internal battery.. i just leave mine plugged in to the cig lighter in my car and i dont have that problem but if you have to use battery power it will drain fast no real fix unless you get a new internal battery and its much easier to just leave it plugged in.
May 22, 2009 | Garmin GPSMAP 172C GPS Receiver
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Dell Inspiron 1100 shuts itself off right after powering it on
if i take out the ram it does not shut off it is a problem with the ram
Mar 06, 2008 | Toshiba P25-S670 Notebook
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Harman Kardon AVR 630 Receiver Logo
395 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
