Question about RCA P52920BL 52" Rear Projection Television
RCA P52920BL (1999)
Tv was given to me original problem would not power up. after moving to my house 5mi. away, found bad fuse set comes on now but has red blue and green shadowes around people or objects. also picture has a bow at top and bottom of screen, going towards center of screen. person who gave it to me says picture was good before tv stopped working. not looking to put to much money in to repairing but would repair if reasonable.
  • dannywb Feb 28, 2008
    thanks to anyone who can get me started in the right direction.
  • craignardo Mar 28, 2009
    i have similar prob but no fuse blew, just convergence issues and i do have the adjustments still in the setup menu, when i select them it fixes prob for anywhere from 2 sec to 5 min. then goes back to way it was.
    any ideas
  • 61 Answers
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Posted on Mar 06, 2008
RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
MY RCA 52 IN TV WONT TURN ON?
MOST LIKELY, THE PROBLEM
IS THE BULB USED IN THE SET?
BY THAT I MEAN THE HIGH INTENSITY REAR PROJECTOR BULB?
DO A SEARCH ONLINE AND THERE ARE COMPANIES SELLING THE BULBS AT A PREMIUM. YOU MAY WANT TO CONSIDER DUMPING IT.........
Mar 14, 2009 | RCA P52920BL 52" Rear Projection...
No Power to Model # P52920BL
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
Dec 30, 2007 | RCA P52920BL 52" Rear Projection...
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
Problem with RCA 52 inch
The flyback has burned a hole in the side,it needs replacing
Dec 03, 2006 | RCA P52920BL 52" Rear Projection...
TV won't power up and blows the fuse
A 10 year old RCa most likly has a bad Horizontal output transistor as well as the main High Voltage transformer and The transformer is no lonmger available from RCA. The replacement wont last longer then a year if your lucky. My advice on a set this old ?? Buy a newer one!!
Sep 11, 2006 | RCA F35670MB 35" TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
261 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
