Question about LG 42PX5D 42 in. Plasma HDTV
High volume on start up in LG cf21s12e tv
I have a LG cf21s12e 21'' tv .It always turnns on with verry high volume. please suggest what to do . please also suggest how to enter the service mode and all settings with defaults. Thanks
  • tintin1 Mar 16, 2008
    full volume on start up , disturb colour balance and geomatry. please tell me how to reset setting in service mode.
Go to main menu
go to audio sub heading volume
turn down the initial setting to the required level and exit back to normal tv
Posted on Mar 21, 2008
    Sergeant:
  • 319 Answers
Wear earmuffs to drown out the noise
Posted on Feb 28, 2008
LG GOLDEN EYE MODEL-CF21S12E, it is running normal, after 2 to 3hours no picture but sound ok. after sw/off few hours it will work normal. every thing check found nomal,pls give suggestion
Check the soldering on the picture tube neck PCB. If possible resolder all the point in the pcb. There is some problem wit the filament voltage. It can be because of drysoldreing.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | LG Televison & Video
My phone start to too many pattern attempts
switch off your phone press & hold volume up button & then switch ON clear the catch or reset your phone to factory default, please keep backup of your contacts firstly
Jun 11, 2014 | HTC One V T320e - 4gb - Grey Unlocked...
I can't program my tv chanel , some of the channerll are missed tv LG flat panel
A simple suggestion that may work--tried to direct enter a channel like 21 enter to see if it goes there? If it does you should be able to go into menu and ADD it to the up/down memory of channels, takes time but if works better than nothing. (can also remove channels in same way---shopping and golf channels are first ones I always delete.
Apr 09, 2012 | LG Televison & Video
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
I have one LG 21" color tv ( MACH 4 model) and it is not getting start.It was working properly with some hissing sound but yesterday it didn't started, the LED at the front panel is glowing but TV is not...
Hissing sound comes from leak EHT transformer but front LED working means your power supply is ok so you need to check horizontal out out Transister and series resitor feeding to voltage from B+ to that transistor if it's gone pls replace the EHT transformer as well
in srilanka EHT is around $5 and transistor is $1
thanks
Aug 27, 2010 | LG Televison & Video
The 32 inch TV started to have promblems turning on at first... then you had to unplug the unit to get it to turnn on, now you cant turn it on at all. Donthe 32 inch TV started to have promblems turning on...
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 03, 2010 | Akai LCT3285TA 32 in. LCD Television
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
LG 42PX5D 42 in. Plasma HDTV Logo
303 people viewed this question
Computer Repairing
Computer Repairing
