Question about Cameras
Protection Kodak EasyShare V1003 How can I delete photos individually when a photo has been 'protected'?
    Sergeant:
  • 319 Answers
Use a hammer...pound repeatedly until camera is no longer recognizable...problem solved!
Posted on Feb 28, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
I'm trying to delete pictures; When I hit "delete", nothing happens
Check this card with your PC , make sure that the protect switch on the memory card is not put ON.
If so check on the side for this small lever to be moved off. this might solve the issue.
Sep 29, 2010 | Kodak EasyShare V1003 Digital Camera
When I turn on my kodak easyshare c813 camera, I can't get past the ''Memory card is protected'' error message. Any ideas?
Yup.  Quite often on media cards there's a tiny switch to write-protect the card so important files can't be overwritten/deleted.  Simply put the switch to the other position and you'll be able to take photos again.
Please rate me if you found this helpful.  Thanks.
Mar 09, 2010 | Kodak Easyshare C813 Digital Camera
Unprotecting pictures
http://www.kodak.com/global/en/service/tutorials/v1073/index.jhtml Go to the picture you protected in your review. (that's the Arrow Play Button) Find the photo then press the menu button. (that's the second button down out of the three that are back there) A menu will appear on the screen, over the top of the photo you want to unprotect. Tap the down arrow, once. You'll see Protect in the list. By tapping it you can turn on and off the protect on your photos. The link above is the Kodak site that runs a small demo on how to do this.
Apr 02, 2009 | Kodak EasyShare V1073 Digital Camera
Unprotect my photos
Try taking the SD card out and slide the little switch to unlock.
Mar 04, 2009 | Kodak EasyShare C613 Digital Camera
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
Cameras Logo
63 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
