Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool thin twin dryer starts and stops after 5 seconds
Hi, I have a whirlpool thin twin stacked washer dryer. I'm having trouble with the dryer. Either the dyer won't start at all or if it does start it only runs about 5-10 secs. and then stops. My husband checked the on/off switch and the door switch and said they were good. Any suggestions. thanks, Linda
  • 1 more comment
  • bark73 Mar 10, 2008
    My dryer won't start. It was working fine and now all of a sudden it just won't start. Is there anything else that could be wrong beside the thermostat? When I push the button it just doesn't go.
  • bigcat27923 Jan 02, 2009
    My dryer won't start at all.  It was working fine a few days ago and now, nothing.  Our unit is wedged in a tiny closet and difficult to get at for repairs.  Having no experience in this area, I guess I'll wait until someone who knows what they're doing can help me.  I'm staying away from 240 volts!
  • Alberto Hung Aug 15, 2013
    If the dryer won't start probably the belt is broken and you need to replace it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
  • 121 Answers
The thermostat might need replace
Posted on Mar 03, 2008
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
1,293 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
