Question about Toshiba Satellite A105 Notebook
KEYBOARD HOT KEY ISSUES SCREEN CHANGING VIDEO SETTINGS..??? HELP
AFTER 2 YEARS ALL OF A SUDDEN MY WIFE HAS HAD THIS TROUBLE.
I NOTICED LIGHT UNDER F10 LIGHT AND I FIGURED OUT THE "FN" BUTTON AND TURNED THE LIGHT OFF THEN THE LIGHT UNDER F11 STARTED FLASHING AND IS INTERMITNET NOW. THE PROBLEM IS THE SPACE BAR AND IT CHANGES VIDEO SETTINGS AND MOST OF THE KEYBOARD IS NOT FUNTIONING CORRECTLY.
IS THIS A MACRO SETTING? OR WHAT COULD IT BE I AM USEING A USB KEYBOARD NOW. I AM NOT AN I.T. GUY AND CAN'T SEEM TO CORRECT THE KEYBOARD I DO NOT THINK IT IS KEYBOARD FAILURE RATHER THAN A SETTING THAT HAS GONE ASTRAY.
PLEASE HELP
THANK
SCOTT
  • 3 more comments
  • GR8TFULSCOTT Feb 28, 2008
    this is a a105-s1013
    this is my first laptop.
    are keyboard failures common as it might be with desktops and cheap keyboards?
    do i fix my laptop keyboard or does it just become a desktop unit now with seperate keyboard and mouse?
    should i anticipate if the keyboard failed that i would have other failures in this unit a should prepare for that.
    scott
    thank s
    i have just read something in the user manual pdf on page 159 and on called "fn-esse" keyboarding it looks to me if you like to type like texting it turns your keyboard in to special mode. when i get home i will try to read farter and turn it off. right now i can't type most keys and those f10 f11 lights would flash and the space bar keeps blacking out the screen while switching the video setting. i think my wife just turned something on that i ca't seem to turn off.
  • Biju Thomas Oct 16, 2013
    Does this happen in safe-mode too (Assuming you are windows user here)
    Tap F8, when the system is starting up... Will get to a menu choice that will have 'safe mode', chose that... the screen / colors will look lower resolution, but all applications should work. Let me know how it goes, before we sort the issue... If you face the issue in safe-mode, its beyond the OS (mostly)
I`m working for Sybols Technology. i have 2 laptop from Toshiba F10 F11 lights flashing, i did everything. But still same ! help?
Posted on Aug 29, 2008
The same happened two me yesteray,unfortunately, i also dont know what to do.
Posted on Feb 28, 2008
Yotube acilmiyo
    Genius:
  • 3,587 Answers
Nope..i'd say your keyboard is shot..
Why did my enter key suddenly no longer function as to enter, when pressed it brings up a toolbar instead of taking to the next line?
your keyboard utilizes keys F1-F10 as re-programmable function keys.to change your current pofile press the razer lycosa logo+functon key(f1-f10) or you can reset your keyboard to factory default settings by pressing the "Razer Logo" button for 15 seconds while the Razer Lycosa is connected to a powered on computer. NB: ALL CONFIGURATION SETTINGS WILL BE LOST WHEN YOU RESET THE RAZER LYCOSA
TO FACTORY DEFAULT SETTINGS. ALL CONFIGURATION SETTINGS WILL NEED TO BE
RE-ENTERED OR LOADED FROM THE CONTROL PANEL AFTER THE RAZER LYCOSA IS RESET.
Jul 21, 2013 | Razer Lycosa Gaming Keyboard
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
My boot priority order changed now my computer wont go to my desktop
Hi!
Sorry, I hope I was not too late. You can fix priority order issue by restoring the default value of BIOS. You can do that by doing the steps below:
1. Reboot your Acer Aspire 5315 notebook.
2. Wait about 30 seconds until you see the Acer logo on your laptop screen.
3. Press the "F2" key on the keyboard to enter the Acer Aspire 5315 laptop BIOS menu.
4. Select the BIOS option "Load Default Setting" using the arrow keys on your keyboard. Then press "Enter."
5. Press the "F10" key to save the BIOS that is reset to the factory default settings.
Hope this helps.
Apr 16, 2011 | Acer Aspire 5315 Notebook
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 17, 2010 | RIM BlackBerry Pearl 8100
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
How do you turn the screen where it will be lighter
Laptops usually do not have dial buttons like normal monitors where you can manually change the brightness with a flick of a switch. However, to replace this, brightness control is usually put onto the keyboard. Try this:
1. Look at your keyboard and look for keys that look like they are marked to perform brightness/contrast control. These are usually symbols written in the F9, F10 and F11 keys but may vary for different manufacturers
2. These keys are usually accessed using another key (the Fn Key). Therefore, while pressing the Fn Key, click on the F9/F10/F11 buttons to play with the brightness control settings
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Computers & Internet
My keyboard shows a lightly lit light below f10
replace ur keyboard, its defect in the hardware!
Dec 30, 2009 | Toshiba Portege R100 Notebook
When my wife logs in her account, the keyboard does not work for her, however it works perfectly for me. I was sure she had changed some settings somewhere, but I could not figure it out. Second question;...
Has the keyboard been deactivated on your wife's account.
Go into control pane and check.
All keyboards have 3 lights above the number pad on the right hand side.
Middle light is for Caps Lock.
On laptops the light might be on the Caps Lock key itself.
Sometimes when you press the key, check the bottom right hand side of your screen and it may tell you that Cap Lock is On/Off
Jul 11, 2009 | Logitech EX100 967499-0403 Keyboard
CLOCK RESET
Press the FN + F9 keys until the time and date appear on the LCD display.
press the FN + F10 keys to go into the Set Mode.
Use the left or right arrow keys to select the hour.
Change the hour by using the number keys on the keyboard or by up and down arrow keys
Use the right arrow key to select the minutes and change the hour by using the number keys or by using the up and down arrow keys Press the right arrow key again to choose the 12-hour or 24-hour format with the up and down arrow keys.
To change the date, use the right arrow key again and use the up and down arrow to select the month. To change the day, use the right arrow to select and the up and down arrows to change the day.
When you are finished, press Enter on the keyboard to exit Set Mode.
hope this helps
Apr 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
Toshiba Satellite A105 Notebook Logo
349 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
