Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Driver hi i think i need the driver for my westell 6100 modem, i had to reformat my comp. and i lost it
  • Draked419 Feb 09, 2009
    6100 works fine on notebook with ethernet but want a driver for usb can find anything that actually works>>>>help?
  • 22 Answers
Not true...i have this exact modem, and it is not plug & play, im searching for the usb driver myself and having no luck
Posted on Jun 20, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Not really needed,, westell modem are plug ang play
Posted on Mar 16, 2008
How do I turnon the USB on the westell 6100 modum?
f you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
Sep 06, 2011 | Westell Wirespeed ProLine 6100 Router...
Lost my internet service
I can't really tell by the picture of the modem of what version you have an f series or g, but I can tell you this for personal experience that the westell 6100 F series is junk. I went with westell 6100 G and my works pefectly. Verizon admitts at www.dslreports.com they have trouble with the 6100 F modem. What verizon said the new firmware was to blame on the 6100 F.
I would like to add that my friend had the exact some problem, he got he G series, and it cure his.
Oct 02, 2009 | Westell Wirespeed LiteLine 6100...
Westell 6100 is blinking Ethernet and Internet lights and Media player buffers and times out. Help
ethernet light should no blink
check the LAN drivers..if possible reinstall them..do a complete powercycle.of the system.
Switch of the pc-modem-router..wait for 1 minute then switch on the router/modem wait for all light to come back-switch on the pc..if intermet light is blinking there might be an issue at the ISP's end.
Http://www.ikarmatech.com
cheers.
Sep 11, 2009 | Westell Wirespeed LiteLine 6100...
Blinking light on Westell 6100 DSL modem
I have a westell 6100 modem also- The light your are talking about always blinks- it blinks as long as the internet is working (it is sending and transmitting data)
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Resuming verizon dsl usb internet connection
If you reformatted your Windows on your pc, there's no need to change the settings of your network connections. The Westell 6100 can either be connected to your pc using the Ethernet port or the USB port if you're using the combo cable or Y-cable. It's more stable to use the Ethernet port for your Lan connection. For the USB, to reinstall the USB connection properly, you'll need the Verizon Installation CD. Make sure the USB is not connected to your PC first before you install it. You just need to follow the CD because it will tell you when to hook up the USB cable to the pc. If you still have the CD, after it runs, you have to select existing customer and then select connect new modem. After that you just to have follow the steps to install the USB connection properly and then your modem will work fine afterwards. If the problem still persists, you can try replacing the cable. If all else fails, it could be a modem problem already. You also need to check your Network Interface Card of NIC as we call it, it's built in your pc. it's the device that allows your pc to communicate with the modem. Normally after reinstalling windows, the NIC is forgotten, make sure you also install the drivers and utilities Cd for your windows.
May 18, 2009 | Westell Wirespeed ProLine 6100 Router...
Computer does not recognize my westell modem thru usb
yes.. you may do that and also, please make sure that the drivers of the USB ports on your computers are installed..
Dec 09, 2008 | Westell Wirespeed LiteLine 6100...
I can't get DMZ on Westell F90-610015 to work.
NEED TO FIND THE DRIVER FOR WESTELL MODEL 6100F cAN YOU HELP?
Aug 11, 2008 | Westell Wirespeed LiteLine 6100...
Westell 6100 network cable
I cant find the gui address to the westell wirespeed e90-610030-06 ?????
Jul 19, 2008 | Westell Wirespeed LiteLine 6100...
USB Connection
Hi floinmist .
Westell 6100 modem by default can only be used for 1 PC . It cannot orit is not enabled to use for 2or morer computers as it creates a conflict within. Ethernet connection is the BEST connection for you to use.> your USB is sent to you by you provider { ISP} or by westell packages. Its is only a spare cable just in case your PC doesnt support ethernet connection ,  nothing else.
To resolve this issue you might want to upgrade your modem to a router w/c is westell versalink . You can connect 2 or more computers  { wired or wireless connection } and is more stable compared to your westell 6100.
Connecting 2 computers could cause slow, intermittent and NO connections at all problems.
IF you have other questions pls feel free to ask and let me know if theres anything ii can assist you with .
Best wishes.
Prince
May 02, 2008 | Westell Wirespeed LiteLine 6100...
Westell 6100 dsl modem
I use a Westell 6100 modem....internet goes out periodically and is not red...just blank....in a few minutes it comes back on....and later out it goes again....
Dec 02, 2007 | Westell Wirespeed LiteLine 6100...
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
348 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
