Question about Sony KP-46WT510 46" Rear Projection HDTV
Red won't move...
Hi folks. I have been reading forums for 2 weeks now and figured out my ic's were bad. Replaced them both (STK392-560) and a 5-amp fuse on the "G" board. Put the set back together and turned it on to see the bow-tie effect was gone but when I flash focused,it didn't help much.
When I'm in manual convergence the red will not move left to right.Up and down is fine.
I turn the set on and the light in front flashes 4 times.Vertical deflection stopped???
Can anyone help me trace this the problem.
  • scales Feb 28, 2008
    Thanks for the quick response. I'm a little slow with the technical jargon. If you could be a little more specific....part #, where located...what board...
    I just buy the parts and tell my brother where to solder!!!
    Any help would be appreciated.
    Genius:
  • 1,030 Answers
Ok this is an indication that the convergence output resistors might been blown.
Posted on Feb 28, 2008
SOURCE:
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Convergence problem???
yeppers..those chips are soldered(more like welded) into the board, and usually runs you around 300 to 400 buckos..
Mar 02, 2008 | Sony KP-65WS510 65" Rear Projection...
My gemmy light show box keeps popping the fuse
Go to planetchristmas.com there are SO many knowledgeable people there. There are forums just for the Gemmy and I suspect you are exceeding too many amps per outlet. But read the forums, you will find your answer and more. Do a search for "Gemmy", Jason Rose has alot of info for this.
Dec 11, 2008 | Toys
Red convergence is off
does the crosshairs move up and down on red... do they move side to side.... if they fail to move at all then the ics must be bad and will have to be replaced.. unless your technical(xperience in solder techniques or know someone that is it will cost you about that. then after that you have to align the set which can be tricky.
sorry
Jan 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Pt-47wx49e service mode
It sounds like the convergence amplifier IC for the red crt is at fault. To check this, go into your user menu and pull up the red convergence. Try to move it up/down or side to side(it doesnt matter). If it moves up and down, then the vertical amp is working. Likewise if it moves side to side, then the horizontal part of the IC is working. If it dosen't move at all, or only moves up/down or side to side, then the IC is bad. There are 2 large IC's on the chassis, mounted to large heatsinks. They have STK392-110 or some variation of an STK392. If yow feel that the IC is bad, change the ic BEFORE you go into the service mode, as you wont need it if the ic is bad. To get into theservice mode: 1 make sure tv is in cable mode 2 set sleep timer to 30 minutes 3 tune to channel 124 4 use volume down on front of set to turn volume all the way down. ( writing will appear in the top left corner). 5 use remote control and press the power button. 6 the 7 button on the remote will put it convergence mode. Good Luck!
Jul 26, 2007 | Panasonic PT-47WX49 47" Rear Projection...
I need help please...
You will need to replace the convergence output IC's and check the resistors in that circuit.
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Verticle lines
I am woundering if the repair folks did the proper job and used the right IC's as alot of NON authorized shops will use the cheap aftermarket repalcement ICs and not even use any new heat sink compound. 4 repairs in 5 years is very excessive! I would not have called the same shop(s) to do the repairs. Put on the test scren on the TV set and see if the convergence is off. If it is make the shop replace them again for free or ask for your money back. Man what a rippoff that is. Good Luck and keep us informed of your progress with the shop and the repair.
Mar 26, 2007 | JVC AV-48WP30 48" Rear Projection...
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
