Question about GE WSXH208A Front Load Washer
Amana Front Load Washer Soap Dispenser
My Amana Front Load Washer is great but I use Kirkland HE liquid Detergent with the cup that comes with it. The cup gets really gummy and with the old top load I just tossed it in with the wash. I noted that it would fit in sideways in the soap dispenser. I was told the water flows into the dispenser carrying out the soap with it. I wonder if it would rinse all the soap out of the cup? I don't want to try it unless someone else had first. Anyone?
    President:
  • 1,294 Answers
I suggest you use soap powder for 'front loading washing machines'. The cartons at the market have them specially marked.
Posted on May 09, 2008
I wash massage sheets and the oil is not comming out of the sheets with the HE liquid laundry soap can I use a none he degreaser without hurting the machine
Don't use non he detergent in washer dispenser it did mess mine up. But u can try adding a cup of white vinegar into the washer itself when you load it to help cut the oil from the fabric it works when I was pool towels in the summer
Jan 18, 2012 | LG WM-2277HW Front Load Washer
I have a lg wm2277 front load washer and the liquid soap cup gets clogged and when I open the tray after the load is finished, it will be full of water. I have tried cleaning the cup but the white stuff...
Switch to powdered detergent. You'll be much happier in the long run. Liquid detergent leaves a residue. Eventually the residue mildews. Powered detergent leaves no residue. Plus you will solve your current issue. Also skip the softener and use plain white vinegar in its place. The vinegar helps eliminate mildew and it also helps release Dey from your clothes in the rinse cycle.
Jan 06, 2018 | LG WM-2277HW Front Load Washer
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Water in detergent dispenser
I think this is normal. Mine does too.
Jun 21, 2008 | LG WM2688H Front Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Soap doesn't go out of dispenser
Make sure you are using a liquid or powder detergent made for front loading machines and has the HE symbol on the front. Also use warm water not cold some detergents may not dissolve completly
Aug 10, 2007 | Kenmore Elite 45986 Front Load Washer
GE WSXH208A Front Load Washer Logo
557 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
