Question about Lands Phones
Help me? with my phone
I have forgot my personalised lock, how do I unlock it?
    President:
  • 1,017 Answers
If it's the SIM Pin number to start your phone you've forgotten, keep entering any numbers, until the phone request the PUK number, available from your service provider.
If it's the phone Security number, I need the IMEI number to give you the Master Code, to reset your forgotten number.
Posted on Feb 28, 2008
I changed the default lock code 12345 and typed a personalised code,but then i forgot it and now my phone is locked.hwow do i reset or deactivate this security code,the phone is a Nokia 6210 Navigator.
http://unlock.nokiafree.org/6210 try using this website. if it doesnt work, you may have to take it to a cell phone unlocking store. doesn't take more than about 10-15 minutes to unlock and restore factory lock code
Aug 15, 2011 | Cell Phones
My sim is locked and I have tried to reset the phone, I cant get it personalised to take the lock of the sim card SGH-E370
Hi,you can unlock your mobile by unlock codes and for codes you can try your current provider or can get it from online providers..once i got unlock code for my mobile from classicunlocking and unlocked my mobile..you can too try getting codes for your mobile and get it unlocked..but before that check whether unlock codes for you country and provider..
Aug 08, 2011 | Cell Phones
Hi there, pls i tried 2 unlock my lgcu720, but it says my phone is not personalise. Pls how du i personalise it? Tnx
This site is nearly perfect and they were recommended highly in the cell phone forums.
http://www.unlock-zone.com
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Dec 07, 2010 | LG Shine CU720 Cellular Phone
Phone locked
WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
Before you start, make sure the battery is charged and all security codes or PIN codes or watever are disabled so we dont have any code prompts interfering with this method.
1. Turn off the mobile phone.
2. Insert a "Non-accepted" SIM card (sim card that wont work) half way in so that when you turn on the phone, it still says "Insert SIM".
3. Turn on the phone.
4. Enter the following code and wait patiently for phone to reset:
*2767*2878#
5. Once reset has completed, the phone will still say "Insert SIM". This is where you need to push the sim card all the way in. You can use a paperclip or a tiny object to push it in if you have difficulty. IT IS IMPORTANT THAT THE PHONE REMAINS ON AT THIS STAGE (TRY NOT TO LET BATTERY FALL OUT) IF BATTERY FALLS OUT, DO NOT PANIC, JUST START FROM STEP 2 AGAIN.
6. Enter the following code and wait patiently for phone to reset:
*2767*3855#
7. After reset is completed, SIM should work and also the reception. Don't get excited, its not unlocked yet.
8. Now we want to make it permanent. First check what locks need to be deactivated with the following code:
*#7465625#
a)
If Network Lock is "Active", put in the following code:
*7465625*638*00000000*00000000#
Message should be "Network Lock has been personalised" or similar.
Then:
#7465625*638*00000000#
Message should be "Network Lock deactivated" or similar.
b)
If Subset Lock is "Active", put in the following code:
*7465625*782*00000000*00000000#
Message should be "Subset Lock has been personalised" or similar.
Then:
#7465625*782*00000000#
Message should be "Subset Lock deactivated" or similar.
c)
If SP Lock is "Active", put in the following code:
*7465625*77*00000000*00000000#
Message should be "SP Lock has been personalised" or similar.
Then:
#7465625*77*00000000#
Message should be "SP Lock deactivated" or similar.
d)
If CP Lock is "Active", put in the following code:
*7465625*27*00000000*00000000#
Message should be "CP Lock has been personalised" or similar.
Then:
#7465625*27*00000000#
Message should be "CP Lock deactivated" or similar.
e)
If SIM Lock is "Active", put in the following code:
*7465625*746*00000000*00000000#
Message should be "SIM Lock has been personalised" or similar.
Then:
#7465625*746*00000000#
Message should be "SIM Lock deactivated" or similar.
Apr 29, 2009 | Samsung J700 Cellular Phone
I forgot my unlock code lg kg 195 plz solve my problum
plz tell me what can i do i m forgot my phone lock.how i un lock my mobile
Dec 08, 2008 | LG KG320 Cellular Phone
Forgot unlock code
my phone is locked, reads phone locked (top of screen) the reads middle: phone lock code:
I forgot the code what can i do to unlock it?
Oct 06, 2008 | Cell Phones
Pin code request when turning phone on
hey everyone.
i have read a couple of threads i have found on the internet and i have tested this on my samsung sgh-c450 locked to telstra. no computer is needed (or cable). i hope this helps anyone with a samsung. WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
4. Aant. Harry----- punt 4 is vervallen ivm met het verwijderen van de emei-code.
*2767*3855#
*#7465625#
Aantekening Harry: Om de codes in te voeren moet je een keer op de rode toets (naast C) drukken, zodat je in het beginscherm komt. Dan kun je codes intoetsen. Dus geen codes intoetsen als je in het keuzemenu zit.
a)
Then:
b)
Then:
c)
Then:
d)
Then:
e)
Then:
"a)" is the common one that usually is the only one need to be done but if other locks are active, i think its best to disable them now while you have the chance.
Now you have unlocked your phone!
Tested on:
SGH-C450
Please test this!
Thank You.
Sep 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Can't remember my phone lock code
i dont remember my phone lock code sonyerickson w800i thanks
May 19, 2008 | Sony Ericsson W800i Cellular Phone
Sim Locked
which network you on ?
have you contact the network provider for help they will assit you more.
if not post back for more help.
riz.
Oct 23, 2007 | Samsung SGH-D500 Cellular Phone
Lands Phones Logo
212 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
