Hi
Thanks
for using FixYa. Please follow the step-by-step procedure---
1. Remove the front panel.
2. Reach underneath drum and behind motor to locate idler
pulley. Push idler pulley to left to release drum belt tension. Remove the belt
from the motor pulley.
3. Remove the drum and belt from the cabinet.
1-- Prepare for replacing the dryer belt by lifting the
lint-screen cover on the top of the dryer. Then remove the lint screen. Skip
this step if your lint screen is inside the door. Remove the 2 Phillips screws
inside the door instead.
2-- After removing the lint screen, lift the cover and
remove the screws that hold the lint-screen housing to the dryer top.
3-- Slide a putty knife between the front panel and the top
near a corner. Lift the corner and repeat on the other side.
4-- To remove the lower panel, insert the putty knife
between the panel and each side. Then twist to release clip.
5-- Place a few wood
blocks under the drum. These support the drum when the front panel is moved
away from the sides.
6-- Loosen the screws that secure the bottom of the front
panel to the dryer sides. Do not completely remove the screws.
7-- Remove the screws that secure the front panel to the
dryer sides at the top. These are accessed from the inside of the cabinet.
8-- Lean the front panel away from the sides and slip the
new dryer belt over the drum. Then re-secure the front panel.
9-- Check that the lip on the back of the dryer drum fits
properly against the seal on the rear bulkhead of the dryer.
10-- Locate the original position of the old belt, and slip
the new belt in place. Keep the grooved side of the belt down.
11-- Push the idler pulley toward the motor and loop the
doubled-up belt around the idler pulley. Slip belt around motor pulley.
12-- Rotate the drum counterclockwise a few turns to check
belt tracking. Then replace remaining components and test run.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
