Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
KitchenAid 575 Professional Mixer
The attachments (wisk, paddle, hook. etc.) now touch the bottom of the bowl when mixing. Is there someway to adjust this or does indicate a particular problem we can address? HELP!
    Problem Solver:
  • 9 Answers
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Posted on Mar 25, 2008
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
Hi, I have a kitchenaid 600 series bowl lift, and I have tried turning the screw both ways to adjust the beater to bowl clearance. The problem is, everyway I tuen the screw, the paddle attachment still...
From the sound of this issue I would have to say the adjustment screws are defective or stripped Normally inside the housing the screw acts like a clamp against the paddle shaft pinching it at the desired height of operation Because Kitchenaid makes alot of their housings from a die cast aluminum tin Mix its easy for the manufacturer to insert the screwed and strip threads causing this issue Replacement of the product at this point is your Only Option for safe Operation of any kitchen appliance.
May 04, 2012 | KitchenAid Food Mixers
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I cannot raise the bowl enough for the batter to fully mix. There is always flour etc. left on the bottom of the bowl. The only way is to stand there and hold the bowl up and tilt it around..Which in my...
There's an adjustment screw as shown in the picture.
http://www.fixya.com/uploads/images/07F1BE1.jpg
Screwing this screw clockwise will raise up the bowl so the mixer paddle reaches closer to the bottom. Don't go too far, the paddle will start hitting the bowl.
May 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
The attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
Sep 04, 2007 | KitchenAid KP2671 Professional 6 Series...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
593 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
