Question about Nintendo Wii Console
Wii remote four blue lights flashing on remote not responding to any button
  • 10 more comments
  • Anonymous May 11, 2008
    first I turn on my wii then I try to turn on wii remote it will not come on
  • Anonymous May 24, 2008
    same problem 4 lights flashing nothin happening when resync buttons are pressed at the same time.
  • Joedims May 28, 2008
    I have the same problem. No resync occurs.
  • Anonymous May 28, 2008
    switched on game no cursor
  • Anonymous May 29, 2008
    four lights on second remote flash and then turn off. remote will not power up. resync buttons have no effect. new batteries installed with no change.
  • Anonymous Aug 13, 2008
  • carynnkimbro Nov 20, 2008
    wii remote flashes then shuts off and wont respond to sync
  • Anonymous Dec 28, 2008
    i cant keep the remote on with remote one so what should i do.thanks
  • nets2201 Dec 29, 2008
    lights are flashing and then goes off. I have also changed the batteries
  • nickarnak Dec 29, 2008
    wii remotes wont sync with wii. Tried everything. including your solution but will not work.
    Remotes are fine, work with our other wii, sensor works with other wii and so do the leads.
  • Anonymous Feb 15, 2009
    FINALLOLY GOT A COP OF FZERO GX AND THE LIGHTS COME UP.... IVE HAD IT THREE DAYS NOW.... NOT EVEN PLAYED:(
  • wiilover May 11, 2010
    You may check out Wii Fix Guideto fix the problem yourself.... This DIY guide will show step by steppictures to fix the problems yourself without any technical knowledge.
    Problem Solver:
  • 5 Answers
Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
Hope this helps
LesPix
Posted on Feb 29, 2008
WII remote will not both sync at same time, one will sync then player two will try to sync and both will go out, have a solution?
Posted on Feb 20, 2009
Required resyncing sorted problem and now back playing.
thanks
Dave
Posted on Apr 19, 2008
2 Suggested Answers
Agent Dort
  • 216 Answers
SOURCE: wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Posted on Apr 21, 2008
Tip
Syncing your Wii-mote to your Nintendo Wii
So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
Here are simple step by step instructions to do so.
1) Turn on your Nintendo Wii.
2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
3) Open the battery compartment on the back of your Wii-Remote Controller.
4) Press the red SYNC button on your Wii.
5) Press the little red SYNC button on your Wii-Mote.
6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
7) If it doesn't work the first time, try again.
Your Wii-Mote should now be synchronized.
on Dec 21, 2009 | Nintendo Wii Remote Controller
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
My wii remotes switch on and all four lights flash blue for about 30 sec then nothing! Any ideas?
You might want to sync your remotes to your Wii hit thhe sync button under the battery coner on the remote and under the wii special compartment
Apr 12, 2010 | Nintendo Wii Console
Wii remotes are not responding to anything. batteries have been changed and lights are flashing but
You need to synchronize them to your Wii. First turn on your Wii. Open the battery compartment on the back of your Wii-mote and the front SD Card door on the front of your Wii. There is a little round red SYNC button on the back of your Wii-mote and a red SYNC button on your Wii in that door. Press the button on the remote and then on the Wii and it should sync. If it doesn't work at first try again. You know it is synched when one of the four LED lights at the bottom of the Wii-mote is solid.
Dec 26, 2009 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii remote turns off
It sounds like you either have a low battery, or your motions may be dislodging the batteries on your controller. When the controller is off and you press a button, check to see how many of the four blue lights on the bottom of the controller are flashing. This tells you how much battery power you have: four lights is full, one light is low. If it's saying your battery is full, try taking the battery or batteries out and putting it back in. Good luck!
Jan 08, 2009 | Nintendo Wii Console
Wii remote
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Wii remote controll
Buy a new sensor bar. None of my 5 Wii remotes had a cursor on screen so I bought a new sensor bar and it worked fine.
Nov 12, 2007 | Nintendo NES Remote Control
Nintendo Wii Console Logo
894 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
