Question about Nespresso Romeo E350 Espresso Machine
F8 Error Unfortunately I pushed a capsule inside this little door instead of on the little balcony and then pressed the button. It stopped while the press was down. I could remove the capsule and could see no damage. However, when turning it on again, it simply shows "F8" on the display and doesn't do anything at all. The press is still half down and the balcony thing doesn't come out fully. What can I do?
4 Suggested Answers
SOURCE: when i turn machine on and put the capsule in i
Turn the machine off with the Power button, and pump the pod receptacle latch on top 3-5 times. Turn machine back on. Ta-Da!
Posted on Nov 07, 2011
  • 6 Answers
SOURCE: with our nespresso machine, when you place the
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
daytoncomput
  • 1511 Answers
SOURCE: Can't get a cup of coffee
Remember...when a unit sits the interior lining of the hot water reservoir tends to dry and debris falls to the floor. If you Purged the Brewer as per page 9 of the manual you would not have this problem. Pg 12 refers to DE-Scaling, which you must do now. Always use Distilled Water to prevent mineral build up.
Posted on Feb 23, 2014
The cd player will not open when you press the open close button
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Mar 20, 2014 | Electro Brand Nostalgic Stereo CD Music...
Nespresso umachine
are you useing the same type of capsules ?whaqt is the model ?
Aug 13, 2017 | Nespresso U C50 Espresso Machine...
I was inside my 2003 Camry and meant to press the
All cars have two sets of key FOBs. Is your 2nd set in the house?
If the windows are down far enough to press the unlock button, can you also reach the door open handle? If so, reach in and open the door. (I must be missing something here).
Anyway, there are several videos on Youtube that show you how to open a locked car. Here are a few examples:
How to unlock your car in 30 seconds
Tricks to Unlocking Power Door When You Lock the Keys In Car Repair Tips
Car Opening
Oct 07, 2017 | 2003 Toyota Camry
2009 nissan murano liftgate button popped inside the door
Spray a little wd40 or similar lube on button and press it a few times. It may just be gunked up. Also make sure it's not hung up on something preventing it from coming out. Try that before tearing into the panel
Nov 30, 2017 | 2009 Nissan Murano
Saeco Vienna - I turned on the coffee machine and instead of the usual whirling of the parts getting into place, it sounds like it is struggling to get into place. I looked inside and the bar is down where...
Hi Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Jun 13, 2011 | Saeco Vienna Espresso Machine
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Cdr tray/door won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Aug 09, 2007 | Philips CDR785 3-Disc CD Recorder
Nespresso Romeo E350 Espresso Machine Logo
1,008 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
