Question about HP OfficeJet V40 All-In-One InkJet Printer
My HP officejet v40 had a paper jam. I cleared it by tugging it from below. it will make pcture copies, but does not take printing instructions from the computer. I tried the usual shut off the printer and turn on again, but no results.[ PS I am not computer swift] Thx Frank Bonaccorso
    Genius:
  • 3,587 Answers
No worries..start by getting new driver for that here
Posted on Feb 28, 2008
Where is the duplexer of the HP 4500 Officejet printer?
its located on the backside of the printer behind an access door. You can find a very good video from HP on clearing paper jams at YouTube. Here's the link:
https://youtu.be/lS1441RmrKY
Fixing Paper Jam HP Officejet 4500 Wireless All in One G510n
Jul 08, 2015 | HP Officejet 4500 Wireless All-in-One...
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
False paper jam on HP Office Jet V40
hp officejet v40 indicates a paper jam and it is cleared nothing
Apr 04, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
How do i access the print cartidges on my hp officejet v40?
Below is a link to the Setup Guide. Click on it and see steps 12 and 13.
V40 Setup Guide
Dec 07, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
The copied image isn't squared evenly on the paper.
What is happening is that the roller that pulls the paper through is slipping so it is pulling the paper through unevenly. You also want to make sure that the guides are snug up against your paper when you feed it through. If it has a lot of slack it can have this problem. If you open the ADF (where you put paper to copy, scan, or fax) like if there was a jam. There will be a roller You can clean these with alcohol and a clean lint free cloth. This could solve your problem but if it return the roller and the pad will have to be replaced.
Hope this helps
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet V40 All-In-One InkJet Printer Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
